350 installed
Today i installed the SBC /700R4 in my 60 GMC. I had a 86 donor truck and used the mounts from it in the 60. I just had to add a 1" shim under the mounts, but after that, it fit like a glove, I mean tight and exact, no slop whatsoever, so it took awhile to squeeze it in there. Had to lower it in with the mounts on the engine, put it in place, mark the holes for the mounts and take it back out. I then drilled the holes for the mounts I had marked and put it back in again. Quite a little work, but worth it. Now, I got a lot of things to install, and also need to make a crossmember and have a driveshaft made. Just glad to have the heavy work out of the way. Thanks to everyone for giving me the right information on how to handle the mount setup.
Re: 350 installed
very cool!
Resistance is Futile
Re: 350 installed
Nice job....always a lttle scary when that thing is hanging over the front of the truck
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 350 installed
Glad to see you've got it in there. Have you changed the front suspension yet? You can likely use the '86 trans crossmember to make one for your '60.
Re: 350 installed
Good Job! Always better to take your time, do it right, and only do it once.
If your looking for any engine dress up parts, let me know...i have a bunch of stuff i'm trying to get rid of from a project that didn't go thru. Few performance parts as well, but mostly dress up stuff. |
