08-19-2010, 10:28 PM | #1 |
Tailgate Repair Questions??
I just bought a tailgate that needs to be patched up and the handle does not work I have another junk tailgate that has an operating handle. Is there a thread that shows someone taking a tailgate apart and welding one??
08-19-2010, 11:20 PM | #2 |
Man of Mini-Talents
Re: Tailgate Repair Questions??
No welding necessary. Just take them apart and make the switch - they just bolt in.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
08-20-2010, 12:08 PM | #3 |
I have unbolted them but how do you take them apart?
08-20-2010, 12:24 PM | #4 |
Under Construction
there are three (3) bolts that hold the handle to the tailgate. there are (2) rods that connect to the back of the handle and connect to the side latches. remove the rods from the handle. the side latches are bolted in with 2 bolts each, and you will be able to pull these out, once the rods are disconnected from the handle..
see the attached pics.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 08-20-2010 at 12:25 PM. |
08-20-2010, 12:31 PM | #5 |
Thanks man I really appreciate back to the garage.
08-20-2010, 12:35 PM | #6 |
Under Construction
i cant recall if the rods are the exact same length and bends, so i would mark them top, bottom ( from handle) and left and right (latches)
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
