Old 08-20-2010, 11:06 AM   #1
Born Lucky
My Next Project!
O.K. then here are my plans!
I just finished rebuilding my monojet and just cleaned up my exhaust manifold and intake. I am getting ready for paint, I am using #225 Alpine Green.
Now I am planning on double the gaskets for the exhaust manifold. I have researched and found out that the 292 is a little problem for sealing in this area. Is this a good idea?
Also, I would like to remove my aligment pins and replace with studs for more sealing. How do I remove the pins?
Born Lucky is offline   Reply With Quote
Old 08-20-2010, 04:49 PM   #2
duallyjams
duallyjams's Avatar
Re: My Next Project!
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-20-2010, 06:30 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The end studs unscrew I believe as there are bolts on mine on each end of the head, mind you this is a 194 head. It leaks at the rear or #5-6 exhaust port, always needs tightening. Double gasket idea, well we always suggest Felpro Gaskets to our customers. I'll look tomorrow if there's a part # for a better gasket. I'll be doing an installation of a 292 into my 4WD project. The manifold on the running motor has cracked flanges at the doughnut so I'll be switching it out with another.
Hollander Interchange states that 63-64 292 exhaust manifold is different from the 65-72, though the later model bolts onto the earlier head.
Old 08-20-2010, 06:30 PM   #4
daverod
SSN 706
daverod's Avatar
screw out
daverod is offline   Reply With Quote
Old 08-20-2010, 06:36 PM   #5
aerotruk63
aerotruk63's Avatar
Originally Posted by daverod View Post
screw out
No need to get nasty, just trying to help!
Old 08-20-2010, 07:23 PM   #6
daverod
SSN 706
daverod's Avatar
You asked for it. I just had to take mine out to put on some headers. As I recall they put up a fight.
Old 08-20-2010, 07:24 PM   #7
daverod
SSN 706
daverod's Avatar
Don't you have some burn outs to go do.
Old 08-20-2010, 07:30 PM   #8
aerotruk63
aerotruk63's Avatar
Think the paint fumes without a respirator has gotten to you already! That's right I was spying on you!
Old 08-21-2010, 08:14 AM   #9
Born Lucky
Photos: Question- If you look at the intake manifold you will see two threaded holes , the large one goes to the PCV and the small one was open.
When I removed the part there was nothing there, just open. So, I look at the manuel and it says nothing. Is it supposed to remain open, uncovered?
Also, I will be cleaning and painting that side of the engine. I know not the way todo it but I figure that as I replace, rebuilt parts around the engine I would clean and paint them.
Old 08-21-2010, 10:31 AM   #10
aerotruk63
aerotruk63's Avatar
Automatic transmission vacuum line, Vacuum gauge in the dash, Power Brake booster or even a wolf whistle could have been installed on that port. There was a vacuum manifold that screwed into the large port that split into 3 to help supply the different requirements. The small port has to be blocked off if it leads to the intake plenum as not to loose vacuum.
Old 08-22-2010, 03:51 PM   #11
Born Lucky
One more photo with more to come!
Half a freshly painted engine #225 Alpine Green
Now I am ready to install the rebuilt carb, intake and exhaust manifold(also freshly painted) .
