Old 08-20-2010, 11:24 AM   #1
mainermikeyd
mainermikeyd's Avatar
cam ideas guys???
Just bought a all original 86 350 with 66k original miles for my Big 10 project truck, still has all the original emmissions hoses an pumps, going to tear all that stuff off this weekend, put some headers on it, I'm looking for what you guys are running on similar trucks?? Has a 700r4 with a 208, an I'm gonna be running 35's on not sure on gears yet but I'm guessin either 3.42 or 3.73's
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 08-20-2010, 11:36 AM   #2
camshaftgsxr
camshaftgsxr's Avatar
Re: cam ideas guys???
it would be best to post this in the engines and drivetrain forum, also some more specs on your motor would help others recommend good parts.
camshaftgsxr is offline   Reply With Quote
Old 08-20-2010, 12:27 PM   #3
von guido
von guido's Avatar
look into comp cams high energy line. They are great for offroad,towing and general daily drivers. They have a tight lobe seperation and not as much duration. They give you ALOT of low down torque so if ya off idle power, than this is the setup for ya
von guido is offline   Reply With Quote
Old 08-20-2010, 02:43 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
the 383 I just sold has an old Melling MTC-1 cam and makes great power down low and continues to make power on up to 5k plus.
Its a 278/288 cam with 204/214 @ .050 dur, .420/.443 lift, 107/117 C/L.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-20-2010, 03:15 PM   #5
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Personally I'd put in a mutha thumpr, the sound is just awesome.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-20-2010, 04:08 PM   #6
nbpro
summitracing has the Melling MTC-1 Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 278/288, Lift .420/.443, Chevy, Small Block, Kit 129.95
nbpro is offline   Reply With Quote
Old 08-20-2010, 07:57 PM   #7
68GMCCustom
Thats a steal...but the MTC-1 is no "Thumper"...just a better then stock, torquey, cam. It makes good power, even tho the lift is a little small.
Kurt -
Old 08-21-2010, 12:06 AM   #8
von guido
von guido's Avatar
thumpr cams are for posers..I have taken at least 10 of them out for customers. Lunati's voodoo cams and Ultradyne are the best off the shelf grinds out there. I run a voodoo 60204 in my 454 and have better idle response,vaccum and power curve than the big mutha thumpr that was in it. Not to mention an extra 21hp and 19 ft lbs of torque at the fly. Granted my gains are partially due to my engine setup.
Old 08-21-2010, 07:34 AM   #9
jasonroman
jasonroman's Avatar
more info on cams please.
im interested, but dont know enuff about em...
i have a 85 with a 350
nothing else done....yet.
want to change intake and carb.
thought might be a good time to have cam thrown in too......
im no mechanic, so i will have to pay for labor...how much should i expect to pay
no trying to jack tread, just looking for info also.
jasonroman is offline   Reply With Quote
Old 08-21-2010, 11:03 AM   #10
nbpro
http://67-72chevytrucks.com/vboard/f...splay.php?f=24
Old 08-21-2010, 12:53 PM   #11
von guido
von guido's Avatar
it all depends on what you want to do with your truck and what gears, converter and compression. On a stock/semi stock motor always go conservative with your cam choice and dont get suckered in to believing that bigger means more power.
Old 08-21-2010, 01:37 PM   #12
jrcaprai
For what you are doing... 3.73 Gears with 35" Tires, your going to want a torquey Cam
Comp Cams has their XE 4x4 Cams made for 4x4's... Can't get much more specific than that
http://www.summitracing.com/parts/CCA-12-239-3/
http://www.summitracing.com/parts/CCA-12-243-3/
jrcaprai is offline   Reply With Quote
Old 08-21-2010, 01:52 PM   #13
LiveAnimals
LiveAnimals's Avatar
I recommend the Comp 268H, its a mild cam for a mild set-up. If you're not going to do much to the engine this will work just fine for you. Please don't over cam it.
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 08-21-2010, 02:12 PM   #14
68GMCCustom
that 268H is even a little bigger cam then the one I mentioned.
Kurt -
Old 08-21-2010, 02:13 PM   #15
olblue81
olblue81's Avatar
Agree on checking out the engine forum here.
But I'll throw my $0.02 in here. With stock heads definitely go on the conservative side. Stock heads typically don't flow much more from .500" lift and above so avoid a cam with more lift than that. Larger duration will make the cam sound better at idle, but you have to rev it higher for the cam to work. From my experience a larger cam will make more power than a smaller one, but it's gets boring waiting for the motor to "come up on the cam". For example, the 350/327 cam I have doesn't really start to pull till 27-2800 rpm. With the stock heads it is wound out by 5200- that's a pretty small window really. I'd prefer something that started pulling about 500 lower and I have a 2wd so no 35s to try and spin.
Newer cam designs are much better than what I have, but it does reference my point. Comp Cams do make a neat FREE engine simulator that will help you select your cam.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 08-22-2010, 07:25 PM   #16
von guido
von guido's Avatar
you have the right idea.... stock sbc valvesprings will only handle up to .480 lift. Go bigger and you have to worry about breaking a spring,piston to valve clearance alongside a sluggish motor. I would not put a "268" cam in a 4x4 because the rpm band. I would recommend like someone else said, a 4x4 specific cam or a comp high energy cam.
