Old 08-20-2010, 01:33 PM   #1
bobcostas
bobcostas's Avatar
sm420 shifter
How to i remove the shifter from my trans?
I'm trying to lift the motor out today. Thank's y'all
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 08-20-2010, 01:39 PM   #2
brew8
Re: sm420 shifter
There is a thin metal piece that clips it in at the top of the shifter tower you need to push it down and turn it to release the clip, good luck, larry
brew8 is offline   Reply With Quote
Old 08-20-2010, 01:40 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: sm420 shifter
Push down on the ball cover and twist. It only needs to twist to release from the two pins. Like changing a turn signal bulb.
