Old 08-20-2010, 05:00 PM   #1
mongoose
mongoose's Avatar
Clutch pedal problem..
I've been converting over to a manual swap today, and I've run into a bit of a snag.
I'm wondering if the manual and auto pedal brackets are different? I'm assuming so, as the clutch pedal's arm is hitting the bracket.. or i could just be putting it on wrong somehow, and where abouts does the upper rod go though the firewall? there's a small hole already in the wall, but is it for something else?
pics would be great btw, seeing how they're supposed to line up, etc.
thanks.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 08-20-2010, 06:56 PM   #2
dropd80s
dropd80s's Avatar
Re: Clutch pedal problem..
Hard to tell with out pics but all the clutch pedal assemblies I have seen are different than autos and need to swap the entire bracket that holds the brake pedal. I think you can mod the automatic bracket but I think swapping all of it out is easier and looks a lot better.
dropd80s is offline   Reply With Quote
