Old 08-20-2010, 06:23 PM   #1
67chevy2wd
67chevy2wd's Avatar
What brake setup for larger tires?
I plan to run 37" or bigger tires on my 71 GMC. What kind of a brake setup should I go with so I still have good braking power? Also the brake booster is not working right now. Is there an upgraded one I can go with?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-20-2010, 06:45 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: What brake setup for larger tires?
You can go with a Hydro Boost upgrade. Make sure you have disc in the front. As for the back it back and forth on disc vs. drum in the back. I say disc.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 08-20-2010, 06:56 PM   #3
67chevy2wd
67chevy2wd's Avatar
I have discs up front. What is hydro boost?
'71 GMC 3/4 ton 4x4
Old 08-20-2010, 09:20 PM   #4
Chevy1TonFun
Grease Monkey
Read through this thread. If you go new it can be pricey, but I have seen it done for cheap.
http://67-72chevytrucks.com/vboard/s...d.php?t=372984
