Old 08-20-2010, 06:59 PM   #1
KansasTruckGuy
Waking a sleeping beast (dormant truck)?
I parked my '72 C10 "out back" about 5 years ago, and started it every week, then every month, then once a year, and then not at all. To no one's surprise, the gas turned into a funky smelling liquid mess, which I didn't discover until trying to fire it up a couple of times with starter fluid. After I discovered the stench coming from the tank, I stopped and pulled the gas tank and dumped out the offending liquid within, and then flushed the tank.
My question is this: Once the tank is reinstalled and fresh gas is added, I'd really like to try starting it again before dealing with a carburator rebuild. Will I do anymore damage than has already been done if I try and start it "as is?" Is there anything I should do to minimize the damage I may have already done to the fuel system? Any other advice? Thanks in advance to all of you gurus out there for your help!
KansasTruckGuy is offline   Reply With Quote
Old 08-20-2010, 07:03 PM   #2
cam.man67
cam.man67's Avatar
Re: Waking a sleeping beast (dormant truck)?
Having had that happen several times to old tractors, I'm not sure that the carb needs rebuilt (at least not yet). If you can flush the fuel line of the old gas, that would certainly help.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 08-20-2010, 07:24 PM   #3
1-PU70
1-PU70's Avatar
Ya I would disconnect the fuel line at the carb and crank the engine till clean fuel comes out. Of course you need to diconect the coil wire and have something to catch the old fuel. Change the fuel filter too. If it doesnt start or runs like crap a carb rebuild would be in order. Good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 08-20-2010, 08:30 PM   #4
cdowns
cdowns's Avatar
last blazer i got with 10year old gas in it i just drained what i could filled with hitest and added fuel system cleaner every fillup for the first thousand or so miles as well as changing the fuel filters a few times in that span// eventually the fuel system cleaner did a good job never had to take that carb apart in the time i had it and put over 30K miles on it b4 selling it off after i blew the tranny
Old 08-20-2010, 08:34 PM   #5
KansasTruckGuy
Smile Re: Waking a sleeping beast (dormant truck)?
Thanks guys! Cleaning out the fuel line is a good idea. Now that you mention tractors, I realize my tractor has the same problem. I guess I've got my weekend plans now! I appreciate your suggestions!
gasoline starting
