Electrical Problems
I'm putting together a 67 C-10 that I started restoring 10 years ago. I'm stuck on a wiring problem. I have no power at the ignition switch. I can use a remote jumper to turn the starter but nothing else. This truck was just a shell when I started so I never had it running at all. One thing that I may have messed up is the starter. There of course are three termanials, the big one goes to the starter than there are 2 small termanials. What if the small ones were hooker up backwards? I'll swap them tommorow and see. Just looking for ideas. Any help would be nice. Thanks
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
The two small terminals on the solenoid, the "S" post on the inside takes the purple wire and the "R" post on the outside takes the yellow wire. If your runnung an HEI type dist, the yellow wire is not used.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
On the front right fender there should be a terminal block.......
There should be a minimum of 3 wires here........if not, won't run.........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
I have three wires at that block and they have power. One of the wires that goes to this block has an inline fuse, what is that fuse for?
I disconnected the yellow wire to the starter becouse I do have HEI. Can I get a wiring digram on line? Thanks
If your truck wiring is set up for gauges, then there should be a small in-line fuse on both sides of your radiator. They are there to protect your amp meter and don't have anything to do with the engine running. The power wire should have a fusible link in it and if your headlights work, then it should be good.
Jim |
Headlights don't work. Where is the fuseable link. Thanks
The fusible link is on the red feed wire coming from the terminal block on the fender. If the wire is facrory it will be about 6" from the terminal block.
Check for power at your altenator, if there is power there, then the link should be good. Jim |
Thanks, I'll check it when I get home.
Old Skool Club
![]() Join Date: Jun 2001
wiringharness.com
This won't solve your problem. But, have you considered a NEW harness? These people will build it to stock specs, or modify it for HEI, one-wire alternators, etc. They are manufacturers, not middle-men vendors. But, you can buy from them, direct.
The folks who answer their phones are very helpful, too...even before you buy.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I would love a new harness, but I'm so deep into this project that I really need to slow down on the spending. I did get a new partical engine harness from wiringharness.com.
