printing is my trade
Aftermarket A/C with Factory Heater
If this has been addressed in another thread please let me know.
I've read complaints about guys not being able to defrost their window with aftermarket a/c. I wanted to know this is possible (or even if anybody thinks its necessary in hot texas): Can I install aftermarket A/C with factory heater core in order to retain a proper defrosting capabilities? My concern is not only the cold but rather when it rains, is it needed to have the defroster? Looking for anybody's input, since I'm hoping to pull the trigger on purchasing the system in the next few weeks..
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184 |
Active Member
![]() Join Date: Jul 2007
Re: Aftermarket A/C with Factory Heater
ttt -- I'd like to know also and in case someone knows the answer.
However, I think the best thing to do is to contact the manufacturer before purchasing to see if the unit has a defrost option. We need the defroster here in Texas like anywhere else -at least where I'm at. I'm not positive on this one but I don't think the old vehicles did not have the ac/defrost option back then. You either had ac or defrost but not both and the ac is what quickly removes the moisture. |
![]() Join Date: Jul 2010
My 'vintage air' sure fit AC unit has heat and defrost. The defrost setting does turn the compressor on and gives your the 'dry air' needed for proper defogging, you just adjust the temp lever for the desired heat range. If your looking to keep the engine bay stock looking, I don't have an answer for you.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
425hp409
![]() Join Date: Oct 2008
See the thread "Vintage Air" today at 7:15 pm.
I have installed many of the Vintage air type systems, the defrost works better than the factory heater/defroster as it turns the ac compressor to dehumidify the air. I had an underdash air system in my truck and I would just turn on the AC with the defroster when I wanted to defrost the windows fast.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
Nostalgic Air Products sells an underdash system that leaves the stock heater system intact, except for a small modification to the heater box as illustrated in the pictures on their website.
Vintage Air and others make great systems but they all supply a fiberglass or plastic glovebox insert.....I have a custom glovebox radio and I don't want to give that up....so the underdash system from NAP is the best choice I've found. I am planning to order one soon. http://www.nostalgicairparts.com/air...system-351.php
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
![]() Join Date: Jan 2001
...but NONE of them offer outside fresh air or blending capabilities. Been there and done that. The evaporator cores on most of those "hotrod" systems equal the size of the ones in a hallway water fountain! After tinkering with two "aftermarket" systems from reputable mfg's that I need not name as they are top suppliers to the industry, I did myself a favor and fabbed in an OEM Four Seasons setup to my original non-air truck. This has been the best addition to date.
Nothing beats the factory system! Last edited by 69sixpackbee; 08-24-2010 at 02:22 PM. |
I totally agree that the factory GM stuff is the best.
#8 | |
Active Member
http://www.nostalgicairparts.com/air...system-405.php |
#9 | |
#10 | |
