08-21-2010, 07:23 AM | #1 |
Master Cylinder
Want to replace the old single master cylinder on my 60 gmc now that i have a v8 automatic. Does anyone make a modern dual master cyl for 4 wheel drums that i can just bolt on without too much modification. May do disk setup later but for the time being, i just want to get the dual cyl installed.
thanks Last edited by skysoldier173rd; 08-21-2010 at 07:24 AM. |
08-21-2010, 08:19 AM | #2 |
Re: Master Cylinder
There is a thread somewhere on here,,,seen it just last night,,but now cant seem to find it,,,67-72 chev truck or a caprice drum/drum master seems to be the one people are using
08-21-2010, 08:20 AM | #3 |
Re: Master Cylinder
08-21-2010, 10:08 AM | #4 |
Re: Master Cylinder
I used that thread and it worked perfect. Gotta hand it to the Chief very good write up
08-21-2010, 10:20 AM | #5 |
Re: Master Cylinder
Problem is i got the old brake/clutch type master cylinder and I don't think any of the ones discussed will bolt up, i think it's a totally different bolt pattern. So, i'll probably have to drill and fabricate to attach. I probably will go with the one from the 67 Impala though. My truck is a 1960 that had the hydraulic clutch.
08-21-2010, 12:00 PM | #6 |
Re: Master Cylinder
I too had the original dual holes on the firewall and I bought a plate from Capt. Fab. to cover the holes and let the dual master cylinder mount up. Contact the Capt. he'll fix you up!
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 08-22-2010 at 09:12 AM. |
08-21-2010, 03:17 PM | #7 |
Re: Master Cylinder
You will need to install a separate MC for the clutch. This is standard procedure when converting the 60-62 trucks to a split brake system. There are several very good writeups here showing different ways of doing it.
Ray Last edited by raycow; 08-21-2010 at 03:27 PM. |
08-21-2010, 03:38 PM | #8 |
Re: Master Cylinder
Ray: I recently got rid of the old v6 with manual and installed a 350 with a 700r4 so i only need the master cylinder for the brakes. But thanks.
08-21-2010, 10:44 PM | #9 |
Re: Master Cylinder
In that case - you could probably use/choose the holes that do line up and add whichever ones don't - OR - Capt Fabs adapter could be used - and you could skip mounting the slave cyl for the clutch since you don't need it anymore (or hack it off the adapter). Sorry Capt Fab - meant to say "politely slice".
08-22-2010, 12:35 AM | #10 |
60-66 Nut
Re: Master Cylinder
I do make a bracket for that application. The link is in my sig below.
I replied to your PM skysoldier173rd.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-22-2010 at 12:36 AM. |
08-27-2010, 01:09 AM | #11 |
Re: Master Cylinder
i got mine from captainfab also. works perfect. i love it
08-27-2010, 02:22 PM | #12 |
Re: Master Cylinder
I too got one from CaptainFab. Very precision piece. You'd think it was made to go on the space shuttle. He apparently takes great pains to ensure these adapters are very high quality. I picked up a 67 chevy truck master cylinder for about thirty bucks at AutoZone and I should have everything i need. Had the old dual master for brake and clutch. Threw it out with the v6 and put in a 700r4 and 350, so the master is dedicated to the brakes only now. Going with 4 wheel drums non power assist for the time being. May upgrade to power disc later. Anyway, Captain Fab is the man, I'm totally satisfied. Anything i need he sells, I'm buying from him.
www.picturetrail.com/skysoldier173rd Last edited by skysoldier173rd; 08-27-2010 at 02:22 PM. |
08-28-2010, 12:40 AM | #13 | |
60-66 Nut
Re: Master Cylinder
Thanks for the compliments guys
