Old 08-21-2010, 12:04 PM   #1
ripdog28
ripdog28's Avatar
To or not to run a rear end Sway bar
Anyone run one? If so Why, Why not? Im thinking of getting a weld in one.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 08-21-2010, 12:11 PM   #2
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: To or not to run a rear end Sway bar
I installed one from a 85 iroc, havent had much street time but so far it works GREAT!
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 08-21-2010, 12:16 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have one on my 72 C10 LWB, made a big difference in how it handles and tows
dwcsr is offline   Reply With Quote
Old 08-21-2010, 12:48 PM   #4
68Stepbed
68Stepbed's Avatar
I've often thought about installing one. The guys at ECE advised me against it. They said the stock trailing arm suspension with panhard bar is pretty stiff to begin with.
If I were to install one, it would be a Hotchkis setup.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-21-2010, 01:38 PM   #5
big_al_71
big_al_71's Avatar
I had one from ECE and once I replaced my trailing arms with the arms from Early classics I took it off as they advice me against it....I do have the front one from ECE and it works like a champ. The back one worked great with the old stock trailing arms.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-21-2010, 01:53 PM   #6
Ackattack
Ackattack's Avatar
I have one on the rear from a LS1 camaro.
However, I recently read an article (I think someone one posted it on here) where some magazine did some testing and got better slalom times without a rear bar.
However, the rear sway bar can be used for tuning the suspension depending on the size. Too large of a rear sway bar can induce oversteer. Yet having a large front bar and no rear bar may cause additional understeer (I assume that a front end heavy pickup will have understeer pretty much regardless).
So if you have a large front bar, a small back bar may help a little. It would also help with towing and drag racing as well.
Ackattack is offline   Reply With Quote
Old 08-21-2010, 03:51 PM   #7
cdowns
cdowns's Avatar
i ran a helwig rear bar with stock front bar// was excellent for long distance towing and with very high heavy loads in the bed// truck handeled excellent both loarded and empty would do again without hesitation
i think the norm is rear should b 2/3 diameter of front bar for proper balance
Old 08-21-2010, 06:36 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I have one on my 84 GMC SWB and the install made a difference on that truck. It gives a more positive grip to the ground compared to the somewhat sloppy ride it had before. when I put the 68 together, I am seriously considering a bar on the back of it.
Frank
piecesparts is offline   Reply With Quote
Old 08-21-2010, 07:08 PM   #9
ripdog28
ripdog28's Avatar
I really do not like my rear end bounding over every little bump. This and i would love it to corner better. I looked at my set up and what i want to do as far as Coil overs in front of the Axle. I will probably go with one that welds up between the rails and drops to the top of the axle. Like the Competition Engineering ones.
69 c-10 BBC
Old 08-21-2010, 10:02 PM   #10
piecesparts
I can corner with some of the best cars, now that I have updated my rear end.
Frank
