Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-21-2010, 12:20 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Intercooler mount?
Well, I know there are a few turbo trucks on here and plenty of supercharged ones, and turbo diesels. Where have you guys mounted your intercooler, I am going to install one on my dads burb, it will be used for a turbo setup and a supercharger setup. I just cant figure out where to put it, I am fine with make a "scoop" for air behind the bumper or something. Thanks guys.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-22-2010, 11:48 PM   #2
c-10ss
Re: Intercooler mount?
i got my boost tubes punched through the rad support and the intercooler mounted infront of the rad. Had to cut out the latch and grill brakets to make it work tho
c-10ss is offline   Reply With Quote
Old 08-24-2010, 06:33 PM   #3
Wild83C10
Wild83C10's Avatar
Mines setup up just the same and I have large procharger intercooler.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 08-24-2010, 07:04 PM   #4
LSX72C10
Same as above! Holes in Radiator support. Intercooler mounted directly in front of Radiator.
LSX72C10 is offline   Reply With Quote
Old 08-26-2010, 11:50 PM   #5
aaronr
Do you guys have more pics in detail how you mounted the intercooler
67-C10 under construction
2002 ECSB Chevy 5.3l with t-70 turbo
216/218 114lsa and 4l80E Built trans w/ 2500 stall
aaronr is offline   Reply With Quote
Old 08-27-2010, 12:05 AM   #6
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I know it's an 89-91 burb core support, but might help
I thought I had more close up pictures. Anyway, I made half circle cut outs on the intake and outlet sides of the core support, and used existing holes in the front side to route the tubing.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-27-2010, 12:10 AM   #7
aaronr
For that intercooler size what is the hp it will cool up too.
Old 08-27-2010, 12:50 AM   #8
Twisted78SS
Wide n'Low
This intercooler is 3.50" thick, and will easily support 1950 CFM's, 1300HP at max efficiency 2.0 psi pressure drop.
Overall Size 26.50" X 15.00" X 3.50"
Core Size 25.00" X 9.00" X 3.50"
Here is the manufacturers site
http://www.treadstoneperformance.com...S9+Intercooler
Air Force Retired
Old 08-27-2010, 01:11 AM   #9
aaronr
Thanks for input.
Old 08-31-2010, 03:29 PM   #10
AirMale
AirMale's Avatar
great info!
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 09-01-2010, 01:18 AM   #11
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
We mounted the intercooler between the front framerails, smoothed slotted the front bumper and made a scoop to channel airflow up through it... we vented the hood on both side to let the air pressure out.
Tom Vogel is offline   Reply With Quote
