Old 08-21-2010, 01:00 PM   #1
Texasdeere
Texasdeere's Avatar
Interior Lights Inop when doors are opened
My interior lights work on my 94 if you use the dash reostat but won't come on when you open the doors. Anyone seen this before? Another fuse maybe?
Texasdeere is offline   Reply With Quote
Old 08-21-2010, 01:07 PM   #2
Colt Cobra
Re: Interior Lights Inop when doors are opened
has it always done this, its possible someone could have disconnected the button that tells the light to come on, after awhile the button wears out and the lights just stay on, alot of people just disconnected them instead of fixing it.
Colt Cobra is offline   Reply With Quote
Old 08-21-2010, 01:20 PM   #3
jb1016
"Oh well, it's a driver."
jb1016's Avatar
They don't come on for either door?
Old 08-21-2010, 01:29 PM   #4
Texasdeere
Texasdeere's Avatar
Yea, both doors don't work. I just bought the truck a week ago. I removed the alarm system a few days ago thinking they would start working but no change.
Old 08-21-2010, 07:51 PM   #5
Texasdeere
Texasdeere's Avatar
I checked all the fuses again. Everything looks great. The door switches seem to work because when you leave the key in the ignition, the bell chimes when the door is open.
Old 08-21-2010, 09:51 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Does your light switch, the one on the dash, also have a button that can turn off the interior lights? I had this same thing happen to my truck and I knew the door jamb switches were good because of the alarm. I posted a question on here and was reminded of that feature on the light switch. When I was reintroduced to the feature and used the button, the lights came on. Whoa. Whatta feelin'....
Member Nr. 2770
Old 08-21-2010, 10:32 PM   #7
Bigg G
Bigg G's Avatar
1) Not sure if your truck has the headlight switch that turns the entry lights off so check your owners manual to make sure.
2) Check to make sure your dome light bulb is not blown.
3) Check the little black buttons (poppers) on the left & right side of your dash to make sure theyre not sticking.
Bigg G is offline   Reply With Quote
Old 08-21-2010, 11:12 PM   #8
1badgmc
1badgmc's Avatar
This is relatively common on the '88-'94 trucks. The plunger switches on the side of the dash that the door pushes can frequently go out. They're pretty cheap and easy to replace. I'm willing to bet that one of those is your culprit.
His truck is a '94, so it doesn't have the Dome Override button.
Old 08-22-2010, 10:50 AM   #9
Texasdeere
Texasdeere's Avatar
The lights all come on with the thumb roll switch, so the bulbs are good. The switch is a little loose in the dash and the cargo light doesn't work either. When I can get my hand on a torx driver I am going to take a look in there. I am going to check the door switches too, but I am pretty sure they are good.
Thanks for all your input Guys...
Old 08-22-2010, 11:16 AM   #10
1badgmc
1badgmc's Avatar
Everything you're describing is exactly what I went through on 2 of my trucks. Both of them needed a new door switch.
Old 08-22-2010, 01:49 PM   #11
jb1016
jb1016's Avatar
The switches were my first thought too, but this ^ plus the fact that both doors fail to turn the lights on, made me think otherwise.
But then, my 93 doesn't have a door chime, so I'm not familiar with that system; maybe the chime is triggered by something other than the door jamb switches? And the switches happen to be bad on both sides?
Old 08-22-2010, 02:50 PM   #12
Texasdeere
Texasdeere's Avatar
Looks like both door switches are bad. The chimes do work on both but not the lights. (That's what threw me off) Each switch has 3 wires, 1 for the lights and 1 for the chime. If I lift up on the pass side switch pin the lights come on. On the drivers side I just unplugged it and used a jumper wire and the lights came on.
Thanks again for all your help. It was the door switches after all.
Old 08-22-2010, 06:28 PM   #13
1badgmc
1badgmc's Avatar
At least it's a fairly cheap and simple fix.
