Old 08-21-2010, 02:21 PM   #1
zane2513
zane2513's Avatar
Horn button assembly
I keep looking but can't find any good info on horn button assembly for my 66 c10. I am wanting to find out the correct order of the parts.
Can anyone help me? I am sure everyone has pulled their steering wheel off before. The PO had mounted a button on the dash for a horn button but I am trying to put everything back to the way it is suppose to be.
Thanks for your help, you guys are great.
just rockin out in Oklahoma
oh and rebuilding my 66' stepside
66' Chevy LWB
in my own way!
zane2513 is offline   Reply With Quote
Old 08-21-2010, 04:07 PM   #2
zane2513
zane2513's Avatar
Re: Horn button assembly
Here is some photos of what I need info on what is the order for these parts?
Am I missing anything or do I have the correct parts?
Can anyone help?
66' Chevy LWB
in my own way!
Old 08-21-2010, 06:12 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The center cap could have a ring of rubber like the predecessors, that allows you to compress the center cap, onto the drum.
Old 08-21-2010, 07:59 PM   #4
zane2513
zane2513's Avatar
aerotruk63
Do have a pic to show me what you are talking about?
I guess I don't understand.
66' Chevy LWB
in my own way!
Old 08-21-2010, 09:27 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I believe the item in question is shown #5 on the attached link:
http://www.classictruck.com/category...tton_Cap_Items
Old 08-21-2010, 09:47 PM   #6
zane2513
zane2513's Avatar
What order should all the parts be in on the steering wheel? I see the parts but what goes first then second then third?
66' Chevy LWB
in my own way!
Old 08-21-2010, 10:06 PM   #7
ray_mcavoy
Hi zane2513,
From the pics you posted, it looks like you have all the pieces.
1st to go in is the spring loaded contact plunger ... that's shown correctly installed in your 4th pic.
2nd is the flat spring metal washer (shown in your last pic). Note that it is tapered (not flat) and should be installed so the outer edge lies flat against the steering wheel. The inner edge should be slightly above the center part of the steering wheel (right around the nut). This is the part that makes electrical contact between the above mentioned plunger and the center of the steering wheel. So that area of the steering wheel right around the nut needs to be clean and rust free for good electrical contact.
3rd is the clear plastic spacer shown in your last pic.
4th is the metal cup (also shown in the last pic).
5th is the plastic ring with the 3 screws (shown in the last pic as well).
Finally the chrome cap with the rubber retainer ring goes on last.
ray_mcavoy is offline   Reply With Quote
Old 01-27-2017, 08:09 PM   #8
ironman3452
ironman3452's Avatar
I just bought the horn button kit to reinstall the horn button back into my 64 panel, I bought it at trucksandcars.com, will take pictures of how I put it in my 64
part number 2-60-06501 60-68 horn ring/ cap hardware kit, inside it has a diagram on how to install the kit
Last edited by ironman3452; 01-27-2017 at 08:21 PM. Reason: to tell the price of the horn ring /caphardware kit
ironman3452 is offline   Reply With Quote
Old 01-27-2017, 08:22 PM   #9
ironman3452
sorry but cost of the kit was 14.00 dollars, www.truckandcarshop.com
Last edited by ironman3452; 01-27-2017 at 08:24 PM. Reason: name of company where i bought the kit
