Old 08-21-2010, 03:14 PM   #1
61apachespeed
what size tires are on stock wheels???
what size tires are you guys running on stock wheels for a 61??
61apachespeed is offline   Reply With Quote
Old 08-21-2010, 03:43 PM   #2
sixbangr
sixbangr's Avatar
Re: what size tires are on stock wheels???
I just had Discount Tire put 235/75's on mine two weeks ago.
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 08-21-2010, 03:53 PM   #3
raycow
On my 60 C-10, which I believe has the same size wheels as a 61, I have 700-15 LT.
Ray
raycow is offline   Reply With Quote
Old 08-21-2010, 10:24 PM   #4
jocko
jocko's Avatar
i am just about to mount 235-75-15s on mine. That's as big as I dare go on the 5.5's and that's probably a stretch - but as you've seen, many of the other folks on the site have mounted the same size - that's pretty much the max section width (235) for a stock wheel. "Stock" is a 215 approx, I believe.
Interesting side note - am in the process of re-painting all my wheels. Thought I was all lucky and stuff to have the "original" spare - and I'm still convinced it is because it still had the never been used decrepit bias ply tire on it. But when I stacked my 5 wheels side by side, it became obvious that the spare was 15x6 while the stock 4 wheels are 5.5". I thought that was odd - because all appearances are that they're all the original wheels (and 5.5 is the correct size). So, maybe someone swapped in an aftermarket spare at some point - but it sure was old and it sure had an ancient tire on it that had never seen the pavement - original tread and all cracked and checked sidewalls of an old bias ply tire. It was Skiiiiiiiiiinnnnnnnnnnnyyyy.
The mysteries abound under this ol thing.
Old 08-22-2010, 12:30 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
My 1960 GMC came stock with 15x6 wheels. Perhaps someone at the dealership just grabbed a spare out of the pile and didn't put any thought into whether it was the right one or not. After all these were mostly just appliances when new, so I doubt a great deal of effort went into making sure they were "correct".
Old 08-22-2010, 12:34 AM   #6
likaroc13
Rollin' Old Skool
running 205/75/15's on my '66 with stock wheels
