Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-21-2010, 11:49 PM   #1
dan42
dan42's Avatar
Where is a good place for your amp?
I currently have mine temporarily in the console of my buddy bucket seats - I'm not crazy about drilling hole out the bottom of the console for the wires, but I probably will, because I can't find a better place for it. My question to you guys would be where a good ground would be? Right now it's attached to the dash (a little hokey). Also, I am getting interference through the amp (buzzing/static from the motor). Where should I avoid running the amp power wires close to so I don't get any interference?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-22-2010, 01:16 AM   #2
Bad70sbchevy
Bad70sbchevy's Avatar
Re: Where is a good place for your amp?
If your gettin interference from the motor, run a ground loop isolator. Mine use to do it real bad from the HEI (have a 50,000Volt Coil) until I put a ground loop isolator and mine and now its clear as a bell plus there really cheap (around $10 at Walmart).
Bad70sbchevy is offline   Reply With Quote
Old 08-22-2010, 03:51 AM   #3
AceX
>130dB Moderator
AceX's Avatar
Ground loop isolator is a good start. I usually tie into the seat bolts for ground, but anything that you can get a solid connection from is acceptable. You also want to keep your ground wire as short as possible and the same size as the power wire.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
