Old 08-22-2010, 12:02 AM   #1
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
One way power steering ?????
First my truck is a 72 LWB 350 engine 350 trans. Ok, I have just finished getting my truck put back together (motor replacement). Also did some front end work, idler arm and balljoints. The power steering used to work fine (before the motor work) but now I only have power when I turn to the left. I thought the pump may have failed so I pulled one from another truck that I have but it did not correct the problem. what could be going on? Has anyone else ever seen this happen?
Thanks for any input or ideas you have
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 08-22-2010, 12:09 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: One way power steering ?????
If I had to guess, I'd say the gear box. Something is either failing inside or got clogged up??
68gmsee is offline   Reply With Quote
Old 08-22-2010, 10:50 PM   #3
chevytruckluver
Ok, I swapped the gear box today from the old parts truck, now I have no power assist, 2 bad gear boxes or 2 bad pumps? I am thinking there must be some kind of check valve thats sticking could it be in the pump or the gear box... I dont know which
Trey
72 Short Step
Old 08-23-2010, 10:42 AM   #4
68gmsee
Active Member
68gmsee's Avatar
hmmm... from bad to worse. I hate it when that happens.
The pump provides the pressure needed by the gear box. But, that is it's only function. One high pressure line and one return line. If you're getting the required pressure, then I'd have to say something else is wrong -gear boxes just happen to be defective or something binding it up.
Hopefully there are some power steering gurus here that can chime in.
Old 08-23-2010, 10:17 PM   #5
chevytruckluver
Power steering gurus needed...I'm not sure what to do next, if I knew what the pressure should be I could check the pump output.
hopefully someone has an idea?
Trey
72 Short Step
Old 08-23-2010, 10:34 PM   #6
sjarrett71
sjarrett71's Avatar
I can't help you but years ago I drove an early 70's Camaro with a similar problem. If you let go of the steering wheel it would steer itself all the way in one direction. It was a PITA to drive on curvy roads or try to take a drink a drink of a soda or anything. It was white knuckle driving at its best!
-Scott-
sjarrett71 is offline   Reply With Quote
Old 08-23-2010, 10:35 PM   #7
Sammy
Same thing happened to me with my 71. Finally the gear box failed while making a slow turn to the left. Mine was the gear box. However there is a small strainer in the power stearing pump behind the pressure fitting that has a orfice that may be your problem. I pulled the pressure line off and the guts behind that fitting does get some trash inside. There is a small hole in there that regulates the output pressure.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-23-2010, 11:57 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I vote for bad box. The reason I say that is if the pump were bad there would have been no power assist before, not just one way because the pump doesn't care witch way you are turning.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 08-24-2010, 12:00 AM   #9
swamp rat
swamp rat's Avatar
Just curious if the pressure line and return line have the same fitting on the steering box? and could they have been swapped? its been a while since i looked at mine..
swamp rat is offline   Reply With Quote
Old 08-24-2010, 06:20 AM   #10
cdowns
cdowns's Avatar
that will happen to a steering box when the box is" adjusted" with the screw to take up the slop in the steering
Old 08-24-2010, 04:15 PM   #11
Texasbigblock
Texasbigblock's Avatar
make sure the lines are clean and not coming apart inside or choked up.
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
