Old 08-22-2010, 02:23 AM   #1
chisler
chisler's Avatar
4 core rad bottom supports.....shroud
I was just wondering what you 67-72 owners have come up with mounting the shroud (bottom) I had a 3 core ,now have a 4 core. Got the correct mounts, bent the flange down on the rad support as per drawing every thing is so far good to go,not to bad of a fit little tweaking.but I think I need item 7 in the second drawing,has any one ever seen this spacer.... and also item 21 I guess I could make two spacers, rad is in and fastened down good, just need some ideas on fastening the bottom of the shroud
chisler is offline   Reply With Quote
