Old 08-22-2010, 02:54 AM   #1
tcs81281
x pipe exhaust
im about to put exhaust on my 69 shortbed with coil springs in rear. im going to use a xpipe kit from jegs and im using 21/2 pipe, does any one have pictures of there exhaust, im running long tube headers. it is possible to fab it up so the exhaust is not lower the the frame? i have a aftermarket tranny crossmember. i was thinking about cutting wholes in rear crossmember and pass pipes through and stand mufflers on there side,hang and dump them in front of axle. any advice or pics would be great
69 c10 shortbed, fullroller 383
shaved markerlights/doors,20inchrims,700r4tranny
www.flickr.com/photos/tcs81281
tcs81281 is offline   Reply With Quote
Old 08-22-2010, 10:17 AM   #2
Lee H
Lee H's Avatar
Re: x pipe exhaust
Not sure about cutting up the rear x member. Several of the after market parts houses (CCP, Brothers) have a bolt in x member with cut outs to pass the exhaust through. With the tube style trans cross member and the rear with holes you can get the exhaust tucked up. The only part that would be below the frame are the headers and the exhaust before the turn up. Looking forward to hearing from more who have done this. Is there enough room for an xpipe?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-24-2010, 10:55 AM   #3
Lee H
Lee H's Avatar
Re: x pipe exhaust
To the top for another round, there has to be lot's of you guys that have been through this.
Old 08-24-2010, 11:08 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: x pipe exhaust
I just put the caddy in my truck and sorry I can't post pics but heres the run down on mine
you need to use some sort of 3/4 header ....the pass side is an easy shot...on the DS your going to need to get under the shift linkage ( so when they build it put it in LOW while building it on the lift this will give you all the clearance you need) then its straight back to your X memeber if you look at it there is are >< cuts in the X already near the ends all I did was make a 3" circle out of them with a plasma and ran the exhaust though there....I have a hanger on one of the bed cross rails just after the X memeber to carry the weight of the muffler .... then the mufflers are on an angle with about a 2' piece of pipe bent to follow the angle of the rear shocks...( this keeps the heat off your Bags?? tires and shocks)...
I reused the Muffs from my 283 ( stardard thrush 18" long or so) and I was amazed how quite they are on the 500...2 1/4" pipe all the way! with no X pipe ?? I would like it to bark a bit more but I guess the sleeper mod works too!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 08-24-2010, 03:01 PM   #5
dznucks
dznucks's Avatar
Re: x pipe exhaust
heres mine. its 2 1/2" with an x-pipe.
http://67-72chevytrucks.com/vboard/s...d.php?t=380456
dznucks is offline   Reply With Quote
