Old 08-22-2010, 10:06 AM   #1
Andy4639
Old member
Andy4639's Avatar
Lightbulb Just in case
I ran across this starter yesterday @ O-Riley's Auto parts. This is a stock item that they carry. It's a direct replacement mini starter for our trucks. This thing is only 1 1/2lbs and it has the strength of the full size delco starter.
I installed it yesterday while it was raining so I haven't drove it yet but it looks like it should be fine. It's got at least 3" of clearance all the way around it form the exhuast. I fired it up a couple of times and it had no noise or grinding. I used a 3/16" & 1/16" chim with 3 washers on each bolt so it would tighten down.
If your having trouble like me this is a good choice I think!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-22-2010, 10:36 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Just in case
Do you have a part number?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-22-2010, 10:38 AM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Just in case
Good Info.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-22-2010, 10:57 AM   #4
Andy4639
Old member
Andy4639's Avatar
Re: Just in case
According to my receit it's a
USL 32390 Starter limited lifetime warrinty. I called O-riley to check and it's for a 91 Caddy and up. This is for a stagard bolt pattern starter. The number is correct for it though!
Old 08-22-2010, 11:00 AM   #5
hotrod100
hotrod100's Avatar
Re: Just in case
32390 is the part number.
My build thread.
hotrod100 is offline   Reply With Quote
Old 08-22-2010, 11:02 AM   #6
hotrod100
hotrod100's Avatar
Re: Just in case
Oops, you beat me to it. LOL.
My build thread.
Old 08-22-2010, 11:16 AM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Just in case
That's it. So far so good. This is a powerful little buger. I can't tell any differance in it over the old Delco starter.
Old 08-22-2010, 11:37 AM   #8
Boog
laying low
Boog's Avatar
Re: Just in case
I was told these ministarters have ball bearings instead of bronze bushings on each end and they just about dont' wear out. Is this the gear reduction type?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-22-2010, 11:37 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
Re: Just in case
I have one that looks just like it, it is for a 1995 Chevy 4 wheel drive with a 350 engine and manual transmission.
They are great little starters and as you said readily available from most auto parts stores.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-22-2010, 12:10 PM   #10
bigguy69
dazed and confused
bigguy69's Avatar
Re: Just in case
are they expensive compared to other starters?
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 08-22-2010, 02:11 PM   #11
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Just in case
x2
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-22-2010, 03:18 PM   #12
Shyguy
Junior Member
Shyguy's Avatar
Re: Just in case
I think they maybe more expensive than the large stock ones. I got mine from my brother and had it rebuilt for $70.
Old 09-17-2010, 07:59 PM   #13
gkesseru
gkesseru's Avatar
Re: Just in case
http://67-72chevytrucks.com/vboard/s...d.php?t=411613
Another thread about starter problems, see my response.
The one in the picture has staggered bolt mounting, which can flex under load (I have seen back end of starter actually move under load).
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 09-17-2010, 08:28 PM   #14
292farmer
292farmer's Avatar
Re: Just in case
will these work on an inline 6? out of curiosity
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 09-17-2010, 08:40 PM   #15
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Just in case
You need to call the store and see. I know they work on the v-6 4.3 engines so they may. They have a couple of them that are for differant applications.
Old 09-18-2010, 01:58 PM   #16
292farmer
292farmer's Avatar
Re: Just in case
alrite, i'll see when i get the chance, when i hop up my 292, i also plan on reducing weight as much as possible through out the truck, i've been researching alum suspension parts, fiberglass hood and fenders(saving stock ones of course in storage) and anything else i find. thanks alot.
Old 09-18-2010, 02:18 PM   #17
raycow
Re: Just in case
At least some of the sixes do not have one of the mounting holes needed for a staggered bolt starter. Look at the bottom of your block where the starter mounts. If you see three holes, it will work. If it has only two holes you will need to use the type of mini-starter that has inline mounting holes.
Ray
raycow is offline   Reply With Quote
Old 10-29-2019, 09:36 AM   #18
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Just in case
This thread is almost 10 years old I know but I have some updated info for this starter.
I went to O-Reilly's last week to get another one and they said the number had been dropped. They only had the regular replacement starter. The big heavy one. Well after doing some searching I found the starter again and they do have them in stock. I remembered it was for a Cadillac but not what vehicle.
2000 Cadillac Escalade with 5.3
Also found that most GM 4.3 have this same starter.
It is only 9lbs compared to the 30 lbs the normal one weigh's. It has plenty of torque to and room for headers and the ramhorns.
Old 10-29-2019, 10:51 PM   #19
Astro-Balls
Astro-Balls's Avatar
Re: Just in case
Will this work for the 4sp manual trans? '68 with big block..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 10-30-2019, 06:20 AM   #20
Andy4639
Old member
Andy4639's Avatar
You may have to look at a different part number. This one is for automatic's. I'm sure they would have one for the 4.3. This one has the angled bolt holes not the straight across ones.
