chevy truck fan
all,
i am wanting to seperate the springs from my hood hinges & would like to know the best/easiest way to do this?? i would prefer to not poke my an eye out!! ![]() any help would be greatly appreciated!! ![]() thanks!! ![]() ps. if it matters i have a '72 chevy hood |
Too many toys,not enough money
Re: hood hinges ?
When they are in the open position, there really is not to much spring pressure on them. Just pull and move to the side that they will come off of. they won't ping pong around the garage.
If everything is still on the truck make sure someone holds the hood open for you!
Looking for all Montana members. PM me or send friend request.http://www.67-72chevytrucks.com/vboa...36#post3813336 |
Re: hood hinges ?
Don't have them powder coated like I did. The heat takes the tension out of the spring and it won't hold the hood open.I ended up sand blasting a pair and painting them.
chevy truck fan
Re: hood hinges ?
mt71 c10,
thanks!! that is what i was wanting to know.... & yes i will have someone to hold the hood!!(lol) |
chevy truck fan
Re: hood hinges ?
johndawelder,
thanks for the info! would you or anyone know if you can "cad plate" them?? i imagine i will just do like you & paint them..... thanks!! |
![]() Join Date: Jul 2009
Re: hood hinges ?
I like the CAD idea.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
Re: hood hinges ?
I built a fixture that had a hydrolic jack in the middle and a spring on each side.When I jacked it up , the springs " spred " apart.I then blasted,primed and painted them.After they were good and dry I put em' back on the powder coated hinges.That was 10 yrs ago ,they still look great.
Re: hood hinges ?
I use a brake spring tool. I tried just screwdrivers and it was no-go.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
Active Member
![]() Join Date: Jun 2002
Re: hood hinges ?
easiest way to get them off is put thick washers between the coils with the hood part way down then when you lift the hood they will come right off. Putting them back on I used a small come-a-long between two fence posts and stretched just far enough so they would go on the hinges, used pieces of wood to protect the paint. Put them on closed the hood the the wood fell out, springs on.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
chevy truck fan
Re: hood hinges ?
ZEKE,
Thanks for the reply. i will try that this weekend or the next...(LOL!) i think i have the idea.... though i may ask for follow up information! (LOL!!) THANKS! |
Old Skool Club
![]() Join Date: Jun 2001
Re: hood hinges ?
One of the truck rags had an article about removal and they used wrenches, like the suggestion for using washers.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#12 | |
Re: hood hinges ?
thanks |
#13 |
Re: hood hinges ?
i use a big a$$ flat head screw driver to get them on and off.
its alittle scary, but as mentioned above, they are not going to take off flying on you. |
#14 | |
![]() Join Date: Jan 2008
Re: hood hinges ?
#15 |
Big Red - Now its a SWB!
Re: hood hinges ?
I used the hook on a tie down strap to hook onto the spring then I wrapped the strap around my hand to get a good grip then I just pulled enough to stretch it then off to the side. To paint it I backed my truck up by a tree then used two ratchet tie downs (one on each side of the spring to the bumper and then to the tree) to pull the spring open enough to paint the whole thing
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
