Old 08-22-2010, 12:15 PM   #1
NC67Chev
NC67Chev's Avatar
Question 67 vent windows
I'm wanting to redo the window weatherstripping soon. In looking around, it appears that the '67 vent windows must be different somehow. Can somebody give me some insight into this? I just want to know my options in case I need to replace the whole assembly, and it appears that only 68-72 repops are available. Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 08-22-2010, 02:16 PM   #2
JimKshortstep4x4
Re: 67 vent windows
67 Vent window glass doesn't have holes in them like the 68-72 vent windows have. Glass otherwise is the same. The frame on the 67 has the handle mount as part of the frame. 68-72 has the handle mounted to the glass using the hole as a place to mount it.
JIm
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-22-2010, 03:45 PM   #3
NC67Chev
NC67Chev's Avatar
Re: 67 vent windows
Thanks for the info. So, if I needed to replace the entire assembly, the 68 - 72 would fit but the handle would be different. It sounds like the 68 - 72 vent window was an improved design. I've noticed that the frame really flexes when it's latched, which might be the reason for the change. Thanks again!
Old 08-22-2010, 04:06 PM   #4
BIG ORANGE
BIG ORANGE's Avatar
Re: 67 vent windows
Not alot of difference, mostly the chrome lever's that lock the vent window closed. 67 have the same lever's as 64,65,66 and 67!
I have a set of 68 vent windows that are of driver shape if your interested in the 40.00 plus shipping!
Best of luck.....
Donnie
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-28-2010, 07:31 PM   #5
NC67Chev
NC67Chev's Avatar
Re: 67 vent windows
I might be interested, since I really don't think I'll be happy with mine after I redo them. I have a couple of questions: Is the frame chrome or painted? Is the latch still tight, or does the handle have a lot of play? Would you mind taking some pictures for me?
Thanks, Mike
