08-22-2010, 02:02 PM | #1 |
best soft top/roll cages
Two part question.
Who makes a good soft top for year round use, my hard top is pretty ratty and I'm thinking a soft top may be the answer. Second part. Does anybody have kits for roll cages or is it all diy. I don't have a tube bender or a decent offroad shop in my area. |
08-22-2010, 02:49 PM | #2 |
SKINNY TIRES RULE!
Re: best soft top/roll cages
There is only one source for new soft tops, http://www.softopper.com/. You can still find used tops occasionally. Kayline, Specialty Top Co (STC) and Bestop all used to make tops, but have either gone out of business or stopped manufacturing them. When used ones come up for sale, they tend to go quickly so you've got to be ready to jump.
For the roll bars, there were several aftermarket "roll bar" kits in the past and used ones come up for sale fairly often. For full cages, you'll probably have to build your own. If you become a subscribing member, you can post a "wanted to buy" thread for either or both items.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
08-23-2010, 12:53 PM | #3 |
PROJECT 7DEUCE
I believe this place sells a full cage for our blazers..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-30-2010, 08:49 PM | #4 |
Which place? This place as in this website?
Also does anybody use there softops in the winter and cold weather environments, how do they hold up? Last edited by Grun DMC; 08-30-2010 at 08:50 PM. |
08-31-2010, 08:02 PM | #5 |
PROJECT 7DEUCE
http://www.swracecars.com/store/Fami...6=13-1519.aspx
sORRY ABOUT THAT MUST HAVE FORGOT TO ATTACH THE LINK..
09-01-2010, 05:31 AM | #6 |
S&W uses the same cage for both trucks and blazers. The part number is 11-1590.
09-05-2010, 07:47 PM | #7 |
People know me
Be careful with the sw cages, My buddy bought the kit for his blazer and says it was basically a really expensive way to buy tube.
He hade to pay a local shop to pretty much build him a cage from scratch, using only a few pieces from his original kit. On a side note, does anyone know if a soft top will fit over a full cage if the cage fits under a hardtop?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels Last edited by bigbadchev72; 09-05-2010 at 07:48 PM. |
09-05-2010, 08:56 PM | #8 | |
SKINNY TIRES RULE!
09-05-2010, 08:58 PM | #9 |
What about this place? I can't say for sure.
www.offroaddesign.com. Sorry; I now see they're Soft Topper tops.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 Last edited by PHAT TONY; 09-05-2010 at 09:00 PM. |
09-11-2010, 10:13 AM | #10 |
Roof: Bad. Sky: Good.
If you want a top that fits from the git-go, wears well and lasts, the Softtopper is the answer. It's basically a modified copy of a top originally designed by BestTop.
I paid an upholstery/hot rod shop to put mine on, but you can DIY if you have the time and inclination. I've had mine on since May and it's been doing great through one of the hottest summers in Georgia history. If it's anything like the Besttop I had on my first Blazer, if you take care of it, it will last for years through every type of weather imaginable. If a rollbar/cage is in your future, as some folks in this thread have suggested, you are probably better off getting a local shop to build one to your specs. Have fun and good luck!
OleSenna |
