Old 08-22-2010, 03:28 PM   #1
HSkinner
4 link vs. trailing arms pros cons
I picked up rear dif out of a cop car with disc brakes and I'm thinking of doing a 4 link. Is there any reason why I shouldn't if I intend on getting it as low as I can with a factory front x member? It's in a 65 c10
HSkinner is offline   Reply With Quote
Old 08-24-2010, 12:08 PM   #2
HSkinner
Re: 4 link vs. trailing arms pros cons
anybody got any ideas???
Old 08-24-2010, 12:24 PM   #3
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
some obvious differences are:
4 link keeps pinion at same level at all ride heights
4 link MAY NOT require a track bar if it's triangulated
4 link you can adjust your pinion angle with easy adjustments for good launch
4 link can be set up to allow more or less forward bite and more or less body roll if cornering is a concern
trailing arms keeps pinion angle fairly the same on the swing up and down
trailing arms require one crossmember that can tuck the trailing arms into the frame
both would give better traction than leaf springs of course.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 08-24-2010, 03:55 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: 4 link vs. trailing arms pros cons
What gear ratio is in that rear end?
Chevy, Ford, or Dodge?
What year is the rear end?
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 08-24-2010, 05:29 PM   #5
HSkinner
I believe it's about 3:23 but I'm not certian. My intention is to make this truck a daily driver that handles good. I probaly won't be at the drags on saturday night but it will be an air ride suspension. Thanks for the help.
Old 08-24-2010, 05:31 PM   #6
HSkinner
any good right ups on how to install one. The one I have is a triangulated.
Old 08-26-2010, 01:28 AM   #7
chopper john
chopper john's Avatar
i used a 96 caprice with disc brakes. c notch trailing arms . and adjustable pan hard. mine was triangulated also but i cut all that off.
chopper john is offline   Reply With Quote
