Old 08-22-2010, 08:59 PM   #1
LandonL
LandonL's Avatar
Vent window rubber, any secret to installing?
I can't get the vent window rubber piece in the corner notch to save my life. I've gotten the hole thing dissembled. Still can't get it to pop in the corner, I've heated it in the dryer and it still wasn't maneuverable. Is there some secret to this I don't know lol?
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 08-22-2010, 10:09 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Vent window rubber, any secret to installing?
Lube it with soap and water. I used a hammer handle to pull it back toward the corner while a friend squeezed it with a pair of channel locks. I don't know if that's the best trick or not, but it worked. I swear, putting the doors back together has been a pain in the arse!
Zoomin is offline   Reply With Quote
Old 08-22-2010, 10:15 PM   #3
Sammy
Now you know why new vent assy are so expensive. I hope after all your work you can open and shut yours as expected.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-22-2010, 10:19 PM   #4
pat 70/71
pat 70/71's Avatar
I had the same issues. take your time . I used wd 40 when I did mine, really not that tough once you get started! stay focused & use the opposite side for a road map. best of luck, Pat p.s., don't drill out the pivot! ask me how I know.
pat 70/71 is offline   Reply With Quote
Old 08-23-2010, 01:41 AM   #5
Rack Man
Straight Dawn soap....no Water!
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 08-23-2010, 02:09 AM   #6
Jayss109
Active Member
Jayss109's Avatar
Use every cuss word you can think of...Thats what worked for me! LOL
Next time mine get old, Im buying the whole assembly. Its been too long for me to remember anything useful, but everything above sounds familar.
J
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 08-23-2010, 02:51 AM   #7
leddzepp
Moderator
leddzepp's Avatar
x 2. Don't drill out the pivot rivet. Instead, drill out the two rivets that hold the bracket to the frame that the pivot is mounted on. These two rivets can be replaced with pop rivets, as well as the other rivets that hold the rubber to the channel. WD40 works great, as well as letting them set out in the sun a few hours. Hope this helps.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 08-24-2010, 06:40 PM   #8
gkesseru
gkesseru's Avatar
I was trying soapy water and WD-40 and still it was a PITA!. The I tried using cable lube. Works great. I actually pushed in most of the channel using just my fingers. I got this at the local electrician supply store. It's made to slide rubber cables inside of metal conduit. Not greasy, cleans up nice.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 08-25-2010, 01:32 AM   #9
project67-stepside
project67-stepside's Avatar
pledge is the cheapest and works greattt.............
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
Old 08-25-2010, 02:23 AM   #10
vectorit
What?
vectorit's Avatar
Not to be the stick in the mud, but I had no luck getting my new seals to fit right.
Sure I could get it to snug up in the corner, but then it would bacon up on the flat edge along the door. Just sucked, and for the amount of time and effort I spent on those stupid things I should have just sprung for the entire wing vent assembly and be done with it. Which I ended up doing anyways, and am happy with the results of going that route.
Of all the things I did on my burb, this stupid little project is one that I get hot about to this day... If it were me, just buy a whole new assembly and be done with it.
JMTC
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-25-2010, 04:24 AM   #11
burb71
Active Member
Board member Seacrow had Ed at Mother Truckers restore his Grandfathers old truck about 5 years ago.
I asked how his truck is holding up since the resto, he pointed out 2 things that are not holding up... the reproduction 69-72 steeringwheel & the repop vent window asm.
Maybe its worth the trouble in the long run, or maybe he got a bad set.
Only time will tell
burb71 is offline   Reply With Quote
Old 08-25-2010, 09:44 AM   #12
MOJO1963GMC
MOJO1963GMC's Avatar
Aint that the truth? After taking everything apart, getting everything powder coated and dealing with rivets I wonder if I'd been better off.
MOJO1963GMC is offline   Reply With Quote
Old 08-25-2010, 10:12 AM   #13
dan42
dan42's Avatar
The repro rubber also craps out really fast - on my '70 I did them about a year ago, and I noticed it was already starting to crack a little on one side.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-25-2010, 11:31 AM   #14
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Thanks for the uplifting news...
Old 08-25-2010, 01:41 PM   #15
classic70
classic70's Avatar
I cut a little rubber off in the corners and lubed it up and it went in, it may not be right but it worked and i have no leaks.
classic70 is offline   Reply With Quote
Old 08-25-2010, 05:40 PM   #16
leddzepp
Moderator
leddzepp's Avatar
NOS is not much better either. I used a set that sat on a shelf for 40 yrs. After one year of being installed, they already are cracking. They were in as perfect shape as you could ever hope to find and fit like a glove, but the rubber still deteriorates even out of the sunlight.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-25-2010, 06:17 PM   #17
gkesseru
gkesseru's Avatar
To keep it from cracking, Armor-all it several times a year.
72 Fleet (died)
78 Step (sold)
00 F150
