Old 02-23-2003, 02:03 AM   #1
ocbaud
Garage Queen Material
knocking sound?
whenever my truck is cold and i just start it and let it warm up, i have to keep my foot on the gas for a minute to make sure it doesnt die. well whenever i blip the gas softly when its cold like that(never going above 1500 rpm's) the engine makes a loud knocking sound that i do not know what it is.
hopefully its a rod trying to push its way through the side of the block
it wants to be replaced by new faster engine
ocbaud is offline   Reply With Quote
Old 02-23-2003, 11:03 AM   #2
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
You might be getting your wish (hoping rod trying to push it's way through side of block), but because it goes away as it warms up I would go with your headers leaking a bit. As the metal heats, it expands and after a short while the leak seals and the knock goes away. I beleive a rod would knock more as the oil warms up and gets thinner.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 02-23-2003, 01:31 PM   #3
ocbaud
headers should not be leaking. and the sound is coming from the bottom of the engine, and i know its not the collectors because i replaced the gaskets about 2 weeks ago.
i do not know if it has anything to do with my cracked flexplate though.
Old 02-23-2003, 01:43 PM   #4
SCOTI
SCOTI's Avatar
ocbaud, I've got the same thing going on w/my 74's 350. Sounds like a diesel when I first start-up on cold am's but after warm-up it goes away (or @ least it's undetectable). It's odd that it goes away so I'm debating whether or not to tear into it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-23-2003, 03:07 PM   #5
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
the reason it goes away when it warms up is because metal expands as it gets hotter. you possibly have a piston slapping against the side of the cylinder walls(i think that is the problem on the new chevys) but as it warms up clearances get tighter and there is no room for it to wobble around. possibly worn rings? just my thoughts...
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
Old 02-23-2003, 05:37 PM   #6
84Stepper
84Stepper's Avatar
THIS SEEMS TO BE A PROBLEM WITH ALL OLD HIGH MILAGE ENGINES. WHEN I HAD MY 305 IT WOULD ALWAYS DO THAT IT WAS REALY ANNOYING. IT'S JUST SOMETHING YOUR GUNNA HAVE TO DEAL WITH TILL YOU GET SOME MONEY FOR A NEW ENGINE.
84 Chevy Stepside, 350, TH350, 268h
Comp cam, Hooker headers, MSD
Pro Billet, Edelbrock Performer manifold
and 1604 carb, 40 Series Flowmasters
dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi
84Stepper is offline   Reply With Quote
Old 02-23-2003, 06:04 PM   #7
SCOTI
SCOTI's Avatar
I thought it was prob the rings but when I did a compression test it had between 155-165 psi on all 8cyl. so that's what what was weird. I would think one cyl @ least would have lower psi than the others or all of them would be lower psi than a 160psi average (from what I've heard, 160 is pretty good).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-23-2003, 11:14 PM   #8
apstguy
LED King
apstguy's Avatar
My 305 does the same, but it might just be my muffler w/ a hole in it. It wants to be replaced with a flowmaster! (I just want sound ok) Whenever I get the money... and remember what to spend it on... WHAT IS IT WITH PEOPLE AND CAPS???
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-24-2003, 02:05 AM   #9
1FaastC10
1FaastC10's Avatar
Eric, you have a known cracked flexplate, correct? if so, that is probably your knocking sound. replace it, and it should go away.
1FaastC10 is offline   Reply With Quote
Old 02-24-2003, 05:54 PM   #10
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
scoti, was the engine hot or cold when you did the compression test? if it was warm then the metal was expanded, thus solving the problem. try it cold
Old 02-24-2003, 08:27 PM   #11
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
hope you get it fixed soon.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 02-24-2003, 08:31 PM   #12
ocbaud
hopefully soon
