08-23-2010, 11:19 AM | #1 |
lowering 1972 lwb
Has anyone ever lowered a1972 lwb pu with 15x10 wheels and 295/50 tires? If so, how low and what method.
08-23-2010, 11:56 AM | #2 |
67-72 parts collector,…
Re: lowering 1972 lwb
A 3"/5" spring drop would be the cheapest.
The front won't go much lower with a 15x10 wheel.
08-23-2010, 12:31 PM | #3 |
Welcome to the board from SC.
There's a few ways to go about lowering your truck from cheap to not so cheap!lol I've lowered alot of these truck buy simply cutting 1 complete round out of the bottom of the front springs and making up a set of 2" blocks for the rearend and that will put you at about a 2" drop on all 4 corners and have your truck setting level also. The other option is to buy 2 1/2 drop spindles and drop springs for the rear. Depending on the drop you want you can also buy drop springs for the front to go with the spindles, I would'nt advise going any lower than a 2" spring up front because the shorter springs drops out of the spring bucket when the truck is being jacked up! jmo..........
Things happen for a reason! |
09-01-2010, 04:22 PM | #4 |
Thxs
09-01-2010, 04:50 PM | #5 |
we cut the front coil springs 2" drop and move the rear leaf hanger bolts up 3" drop ON 81 THO see post 11 http://67-72chevytrucks.com/vboard/s...d.php?t=359363
where we got the idea Last edited by nbpro; 09-01-2010 at 05:54 PM. |
