Old 08-23-2010, 08:19 PM   #1
coggonobrien
what's it take to convert to front disc?
looking to change my 70 blazer from front drum to disc. Is there a complete kit to do it out there? if not what's it take and a donor would be tough to find.
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 08-23-2010, 09:35 PM   #2
1972CST
1972CST's Avatar
Re: what's it take to convert to front disc?
You should be able to find a disc brake dana 44 axle from a 72-79ish truck, blazer or burb. Im not sure when they went to 10 bolt corp. front axles. Just make sure your gear ratio matches the rear. Your brake hoses will have to be chamged I think. I just picked one up for $80 with flat top knuckles.
1972CST is offline   Reply With Quote
Old 08-23-2010, 09:48 PM   #3
coggonobrien
are they tagged or stamped witht the gear ratio?
Old 08-23-2010, 10:02 PM   #4
AJs72K5
AJs72K5's Avatar
4x4, right? Gears on the donor axle don't matter. Everything from the spindles out is interchangeable. This includes the GM 10 bolts. Break the outers down to the knuckles and swap then to your axle.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 08-23-2010, 10:04 PM   #5
coggonobrien
yea 4x4, that's good, so i can just remove my drum ends and replace with disc, albeit with new rotors/pads. how tough are the calipers to rebuild? also will i see a differance in my backspacing requirements for wheels?
Old 08-24-2010, 11:02 AM   #6
ChadGiles70
If you want a kit that you can get one from some websites like www.lmctruck.com I would shop around to make sure that they are the best price though.
ChadGiles70 is offline   Reply With Quote
Old 08-24-2010, 12:26 PM   #7
drunkbus
New Member
drunkbus's Avatar
I just pulled the Dana 44 out of my 72 Blazer. I would sell you everything from the knuckles out for $160 shipped. Which includes new lifetime warranty Warn hubs with less than a 1,000 miles of street driving on them and newer brakes. I can get photos after work if you're interested.
drunkbus is offline   Reply With Quote
Old 08-24-2010, 01:23 PM   #8
coggonobrien
i'd buy it all but i'm not ready to do the swap yet, just researching, thanks though
