08-23-2010, 08:36 PM | #1 |
Exhaust smoke
Just rebuilt my 250 L6. Started up great BUT.......now there is white/blue smoke coming out the tail pipe. This was not there before. This was my first rebuild. Does this mean my head gasket is bad and the smoke is from burning oil? I torqued the head bolts to 95 ft-lbs as my Haynes book told me. I have no leaks any where. Need advice before I pull the head off again.
08-23-2010, 09:15 PM | #2 |
Its a Truck Thing......
Re: Exhaust smoke
Go back through and check the basics, do a compression test if you have the tools, check the fluids for mixing. White usually means antifreeze is burning and blue is oil. Something is mixing somewhere....
How much of a rebuild did you do? Full with piston rings or just the top end? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
08-23-2010, 09:47 PM | #3 |
Re: Exhaust smoke
Yeah, we need to know how in depth the rebuild was. Was it a hone and ring job with some new bearings, or was it a full machine shop job?
08-23-2010, 10:06 PM | #4 |
Re: Exhaust smoke
New pistons and rings, and rod bearings, cleaned build up on all valves. And all new gaskets. No machine work. Also I noticed the oil gauge reading very very low.
08-24-2010, 06:34 AM | #5 |
Re: Exhaust smoke
08-24-2010, 07:09 AM | #6 | |
Re: Exhaust smoke
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
08-24-2010, 09:16 AM | #7 |
Re: Exhaust smoke
Did not hone the cylinders. They seems very smooth. I did clean everything with brake parts cleaner.
08-24-2010, 10:04 AM | #8 |
Active Member
Re: Exhaust smoke
08-24-2010, 12:00 PM | #9 |
Re: Exhaust smoke
I disagree with the honing, unless there was cylinder damage.
http://www.snowvalley.20m.com/bikes/dnthone.htm Did you get the head, specifically valve guides and seals looked at? |
08-24-2010, 12:19 PM | #10 |
Re: Exhaust smoke
did you measure the ring gap b4 installation?
08-24-2010, 04:25 PM | #11 |
Active Member
Re: Exhaust smoke
Re. honing: Yes, it definitely helps to seal the rings. Old engines that have a lot of miles on them have an uneven surface that doesn't excactly match the circumference of the new rings.
I've heard of some saying it's not necessary, but 100 yrs of machinists, mechanics and engineers saying it does is enough to convince me. Reason for machine work on an old engine is wear on the cylinders may be uneven or you could have cylinders that are not perfectly round requiring reboring. |
08-24-2010, 04:51 PM | #12 |
Re: Exhaust smoke
How much cylinder ridge did you have? Did you remove the ridge before installing new parts?
Ray |
08-24-2010, 06:02 PM | #13 |
Re: Exhaust smoke
Another question is did you stagger the ring gaps on the piston?
My build thread. |
