08-23-2010, 09:29 PM | #1 |
5/8 bore shock, 1/2 bolt control arm
does anyone know where i can easily find a shock reducer or new inserts for my shocks, i am running the front shocks spec. for the front dropmember. the only thing is that they have a 5/8 mounting hole, my factory lowers have a 1/2 hole. not enough room in the control arm to drill them to 5/8, i have to either machine one(do not want to do this unless i have to) or insert a whole new bushing set with a 1/2 hole. any help would be great, thanks daniel.
08-23-2010, 10:56 PM | #2 |
Re: 5/8 bore shock, 1/2 bolt control arm
you cant enlarge the hole in the arms 1/8 inch?
08-24-2010, 12:12 AM | #3 |
not enough room between the shock mount and the control arm for a 5/8 bolt, washer, and nut. barely enough room for the 1/2 inch.
08-24-2010, 01:40 AM | #4 |
press it out and either look to see if you got larger ones in the backs with the bolts or just get some tubing and make some correct size ones.
08-24-2010, 09:43 AM | #5 | |
Happy to be here
I bought a 5/8"x2" bolt and a few 5/8" jamb nuts. I ran the bolt through the mounting tab toward the outside and cinched a jamb nut down. Mounted the shock and another jamb nut. I plan to use Loc-Tite once I get to final assembly to ensure the nut stays in place.
08-24-2010, 12:39 PM | #6 |
In a city the size of Houston I would expect to find a hardware or fastener supply that carries 5/8" x 1/2" bushings. That should be your fastest and cheapest fix.
Ray |
08-24-2010, 06:58 PM | #7 |
man you would think, but that is exactly what i have been doing with every aspect of this project, seems that the one thing that was going to be easy takes two days to fix. anyway, thats what custom is. well i found a sleeve that is 21/32 od and 1/2 id . tired of messing with it, i will turn this one down and call it good. thanks again for all the help. daniel
08-24-2010, 07:10 PM | #8 | |
Registered Cruiser
08-24-2010, 08:32 PM | #9 |
ken ... those shocks are the cat's a$$!
08-24-2010, 09:03 PM | #10 |
i hope these shocks are good, had to trim them side to side to fit the mount in the a arm and install spacer. have to custom make them each time. ha ha. oh well. i live for this $#1@. here is a pic of the finished product. i relief cut the spacer to give it clearance, then i pressed it with my arbor press. then i drilled i back to 1/2 inch.
08-25-2010, 12:21 AM | #11 |
Happy to be here
Why thank you sir....I think...
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-25-2010 at 12:21 AM. |
08-25-2010, 02:00 AM | #12 |
I agree. Those shocks are shocking!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 Last edited by ERASER5; 08-25-2010 at 02:59 AM. |
08-25-2010, 07:17 AM | #13 |
08-25-2010, 10:43 AM | #14 |
Happy to be here
Ohh, like those are sick, or whack, or dope or....Yeah I got it, just thought it was funny.
Meanwhile I made some progress on my install- LINK
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-25-2010 at 10:44 AM. |
