Old 08-23-2010, 10:24 PM   #1
61apachespeed
ball joints
has anyone done ball joints for 60-62 and what is up with 340 dollars for ball joints. does any one know were to get them cheaper.
61apachespeed is offline   Reply With Quote
Old 08-23-2010, 11:50 PM   #2
62 Bowtie
62 Bowtie's Avatar
Re: ball joints
yet another reason people do the c-member swap ball joints for the 78 19.95 the entire c-member was 150
62 Bowtie is offline   Reply With Quote
Old 08-24-2010, 01:08 AM   #3
Captainfab
60-66 Nut
Re: ball joints
Sounds like a good time to upgrade to front disc brakes......
Old 08-24-2010, 02:45 PM   #4
raycow
Re: ball joints
If you are willing to give up the T-bars, the cheap fix is the crossmember swap already mentioned. Unfortunately, there is no easy solution if you want to keep the stock suspension, which is what I want to do.
I have seen one truck where an obviously expert welder cut off the outer ends of the stock control arms and welded on the ends from a later truck. Clearly, this is not for the faint of heart, but if you can find someone with the necessary skills to do the job, I would say go for it.
Ray
raycow is offline   Reply With Quote
