Old 08-23-2010, 10:28 PM   #1
eagleuh1
eagleuh1's Avatar
LS swap ?
Has anybody thats done an LS or 4.8, 5.3, 6.0 swap just changed the speedometer out of the stock guage panel, swapping in an electronic such as Autometer or Stewart Warner, and kept the rest of the stock guages? I'm interested in trying this to save some money. Looks like would have to erase the numbers on the plastic lens though. Anybody.? Post pics if possible. Thanks.
eagleuh1 is offline   Reply With Quote
Old 08-24-2010, 09:42 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: LS swap ?
you can use a convertor and it will allow you to use your existing speedo, however the converter isnt cheap at all. I cant remember the brand but I know someone on here will chime in, also look at Thealien's write up in the sticky
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-24-2010, 10:22 AM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: LS swap ?
you can do an LSx swap w/o changing your trans if you want...or go for an older non-computer controlled overdrive like a 700-R4, 4L60 (w/o "e"), or a 200-4r
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-24-2010, 10:31 AM   #4
juice03
juice03's Avatar
Re: LS swap ?
You can also bolt your TH-350/400 or powerglide to the LSX block but a shim is required. I have done 4 of these swaps with a 5.3 and 6.0 in older vehicles and used the original trans and added the shim GM#12563532 and the bolts for the the shim GM#12563533.
These swaps are great, CHEAP since you can pick up 5.3's and 6.0's for $500-$800 with under 100k on them.
Mike
1969 Chevy C/10 shortbox, built 396 with factory a/c, 700R4 with eaton posi trac and 3.43's
1968 Chevy C/30 project, in progress.
1967 GMC 1/2t longbox
1935 Chevy Master Coach Prostreet
1936 Chevy Master Coach
1952 Chevy Coupe
1950 Pontiac Cheiftan
juice03 is offline   Reply With Quote
Old 08-24-2010, 01:11 PM   #5
eagleuh1
eagleuh1's Avatar
Re: LS swap ?
Alright, the question was......I already have the engine and tranny in and running and driveable. 5.3 with 4l60e. That ain't going to change. Guess I should have stated that first. Already looked at TheAliens build, and what a fine detailed build it is, Nice. I'm interested in just saving some money on the guages, since my guages all work as is hooked up the the 5.3, just not the speedo. Not interested in spending the money on the Abbott Xbox converter. Speedo's are a little over$100. Wiring is cheap. Also looking for a matching tach for the center hole. Anybody done this. Speedo and tach changeout only?
Thanks for all the replies.
Old 08-24-2010, 04:35 PM   #6
juice03
juice03's Avatar
Re: LS swap ?
Sorry man, but at least now you know if you want to use an older trans that the spacer is need. lmao
Mike
1952 Chevy Coupe
Old 08-24-2010, 05:36 PM   #7
Thealien
Thealien's Avatar
Re: LS swap ?
Nice looking install. Good luck with the speedo. I would think someone creative should be able to add just the speedo and keep all the stock gauges. I would bet that the lighting for the speedo will be much brighter than the other stock gauges. Only thing I don't like about my original dash is the lights are not very bright.
Old 08-24-2010, 06:17 PM   #8
eagleuh1
eagleuh1's Avatar
Re: LS swap ?
Well, I guess I'm going to have to get creative. Unfortuanetly, that usually ends up being more expensive, for me anyways. LOL. Thanks for all the replies though.
Old 08-24-2010, 09:42 PM   #9
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: LS swap ?
What about getting one of the squarebody electric speedos and converting your face to it.
Search for some pics in the 73-87 section. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 08-25-2010, 09:36 AM   #10
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: LS swap ?
Hey, that's not a bad idea. Actually, if a person was to take their time, I bet they could fit all the gauges from a square body cluster behind a 67-72 bezel. Might need to hit up a glass shop for some Lexan to make a new lens, but I bet it could be done.
Hmmm, now you have me thinking. I have a 69 that's going to get a 5.3 soon, and I have many complete 67-72 and 81-87 clusters.....
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-25-2010, 09:43 AM   #11
faribran
Re: LS swap ?
Bob,
i like the way you think...... let us know what you come up with........ will be listening
faribran is offline   Reply With Quote
Old 08-25-2010, 09:45 PM   #12
Big Port Jimmy 6
Addicted to Rust
Re: LS swap ?
[QUOTE=glock35ipsc;4156555]Hey, that's not a bad idea. Actually, if a person was to take their time, I bet they could fit all the gauges from a square body cluster behind a 67-72 bezel. Might need to hit up a glass shop for some Lexan to make a new lens, but I bet it could be done.
Hmmm, now you have me thinking. I have a 69 that's going to get a 5.3 soon, and I have many complete 67-72 and 81-87 clusters..... [/QUOTE
Remember even a blind squirrel finds a nut once in a while. Jay
Current trucks:
Old 08-26-2010, 10:11 AM   #13
glock35ipsc
Re: LS swap ?
Bob
Old 08-26-2010, 05:31 PM   #14
eagleuh1
eagleuh1's Avatar
Re: LS swap ?
I'll have to look at that. Thanks. I do have a 96 S10 cluster with TAC, might have to try that also.
Old 08-26-2010, 11:33 PM   #15
Ratpowerd67
Re: LS swap ?
i am useing the programable 5" autometer speedo in the factory location and useing the 5" tach where the fuel used to be. for a fuel guage, im useing a 2" autometer and mounted it in the lower holes. im useing a 67 panel and i cut my own holes on the bottom. i fabed up my blinkers, high beam , and my engine check light behind a piece of plexi glass with LEDs from jegs in the 3" center hole that you are refering to...i can take a pic if you want.....hope this helps.
Ratpowerd67 is offline   Reply With Quote
Old 08-26-2010, 11:55 PM   #16
Ratpowerd67
Re: LS swap ?
i know that did not help your question but i thoght i would throw ideas out there.
Old 08-27-2010, 02:16 AM   #17
dave69
Re: LS swap ?
I have been looking for a complete LS or newer TPI engine/tranny found a few but not many hard to find comlpete, where are they for $500-$800? So far have not found any LS1 in Canada. Where should I be searching on internet? I am in Vancouver area I would like get more info from you on the swap can I contact you by phone? Thanks Dave
dave69 is offline   Reply With Quote
Old 08-27-2010, 09:47 AM   #18
68GMCCustom
Re: LS swap ?
The car motor/trans combo's are more expensive and you may have to pay more up there. Look for a 4.8, 5.3, or even 6.0 out of a truck or SUV...they make the near the same or more hp. Trans will be a 4L60-e, 4L60eHD, or 4L65e (4L70e if its from a TBSS or VMax truck). I don't think I'd go TPI w/LSx solutions the available.
Kurt -
Old 08-27-2010, 10:03 AM   #19
glock35ipsc
Re: LS swap ?
The LS engines are today what the small blocks have have been in the past 50-some years.
Search through http://car-part.com/, I saw a ton of engines and trannys in BC.
Bob
Old 08-27-2010, 10:30 AM   #20
dave69
Re: LS swap ?
I would like to talk to you about these motors and if you know of any in Alberta I am in Vancouver. Please let me know. Thanks Dave
Old 08-27-2010, 11:05 AM   #21
68GMCCustom
Re: LS swap ?
Which flexplate are you using?
Kurt -
Old 08-27-2010, 05:38 PM   #22
eagleuh1
eagleuh1's Avatar
Re: LS swap ?
Yeh, throw in a picture if you can of your panel, Did you have to cut up the metal backer to get the speedo in?
