Old 08-23-2010, 11:55 PM   #1
steves1967
steves1967's Avatar
Drum to Disk brake help needed
I'm helping my buddy with his 70 GMC swb, he got a disk brake conversion kit from the Truck Shop, and a power booster from Kragen Auto Parts. He put the whole thing together and asked me to help bleed the brakes for him. Seems that the truck will stop, but he needs to pump the pedal a couple times to get a firm pedal. I bench bled the master cylinder, and I bleed each wheel 3 times around, no air bubbles in the system, yet he still has a soft pedal until he pumps it a couple times. Am I missing something here? Engien makes 17" of vacuum, the m/c isnt leaking. Attached is a pic of his setup, am I missing something?
Thanks!!
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 08-24-2010, 12:49 AM   #2
cheyenne shortstep
cheyenne shortstep's Avatar
Re: Drum to Disk brake help needed
May need to adjust the pushrod.
cheyenne shortstep is offline   Reply With Quote
Old 08-24-2010, 01:54 AM   #3
ERASER5
ERASER5's Avatar
Push rod adjustment is critical to good brakes. The booster pin needs to be set correctly too. I had to do both for mine. To get the pin adjusted just right, I had to remove it and grind a little.
Do you have a residual valve inline? That looks like a disc/disc MC. That's fine if it is, but a 10 lb. residual valve is needed for the rear drums or soft pedal will occur. The difference is night and day.
Here is a linc to Master Power Brake's Tech support. This page helped me.
http://www.mpbrakes.com/technical-su...sc-drum-01.cfm
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-24-2010, 01:56 AM   #4
steves1967
steves1967's Avatar
Thanks for the info, he doesnt have the residual valve yet. I have the pushrod adjusted pretty well, about 1/2" travel before the pushrod contacts the m/c piston. Is that too loose?
'22 Chevy Tahoe RST
Old 08-24-2010, 01:58 AM   #5
steves1967
steves1967's Avatar
Also I believe he has the front port on the m/c plumbed to his front brakes, is this correct?
'22 Chevy Tahoe RST
Old 08-24-2010, 05:27 AM   #6
ERASER5
ERASER5's Avatar
Yes. That is too loose. The booster pin should be 1/64" from the MC.
For that type of MC, the front should be the front brakes.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 08-24-2010, 12:37 PM   #7
steves1967
steves1967's Avatar
Great tanks, is there anywhere in particular that I should mount the pressure valve?
'22 Chevy Tahoe RST
Old 08-24-2010, 01:48 PM   #8
ERASER5
ERASER5's Avatar
I put mine along the frame rail.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 08-24-2010, 03:21 PM   #9
68 TT
Still plays with trucks
68 TT's Avatar
It is possible the push rod coming out of the booster is too short for the master cylinder and it is only getting partial travel of the master cylinder piston as a result.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-24-2010, 09:01 PM   #10
ERASER5
ERASER5's Avatar
Which is why I said to check the booster pin, gave a linc saying the same and related that I had to adjust mine. The pin is screw adjustable.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
