Old 08-24-2010, 01:55 AM   #1
lindblom71
How Low for the long beds?
I would like to do a 5.5" and 7" drop on my 71 long bed. Would i need to notch the frame for that? Ide like the 20" wheels since its only a weekend toy. plus having 20" Wheels with low pro's will keep me from burnin rubber to much on the steet. thats what they make race tracks for.
hook me up with so quality lowering kits for the trucks.
71' 406ci SBC. 13.2 1/4mile with room for improvment.
lindblom71 is offline   Reply With Quote
Old 08-24-2010, 05:07 AM   #2
OARNGESI
OARNGESI's Avatar
Re: How Low for the long beds?
After 6in youll need to notch the frame
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-24-2010, 10:37 AM   #3
78bronzechariot
78bronzechariot's Avatar
Mine is lowered 4.5 front and 5 rear. IIf you want to go any lowered in the front, you will need a dropmember. I have to be extremely careful on rough rough roads to avoid the stock front crossmember from hitting the ground. I am also running stock sized tires 235/75/15.
78bronzechariot is offline   Reply With Quote
Old 08-24-2010, 10:42 AM   #4
Slick67
Sofa King Crazy!!
Slick67's Avatar
Absolutely notched. Lowering springs and drop blocks may get you that low in the back. If you bag the front you will get a better ride and be able to have the look you are going for. You could run a 20X8.5 & 22X10 like my combo and not rub, but it's close.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
