New To 67-72 Trucks Need Help
HI ALL REALY LIKE BORAD I HAVE LEARNED ALLOT ALLREADY
I HAVE JUST GOT A 70 GMC CUSTOM C-10 LWB WITH ALL OUTER TRIM IN GOOD SHAPE VERY LITTLE RUST JUST SOME REAR CAB CORNERS VERY MINOR NO DENTS JSUT HAVE BRAG ON DEAL OF THE YEAR IT RUNS BUT NEED MOTOR ONLY PAYED 400 BUCKS FOR THE TRUCK POOR GUY DID NOT KNOW WHAT HE HAD HIS LOSE LOL MY ??IS THE BADGE ON SIDE SAYS 1500 V-EHIGHT HOW DO I FIND OUT WHAT MOTOR WAS ORIGANL MINE HAS BEEN CHANGED I KNOW I THANK IT IS A 350 IT HAS NEW CARB ,DRIVE SHAVT ,BATTERIE,GOOD DIST. THANKS TO ALL WHO REPLY JBARTGMC-10 |
Welcome to the board from Texas
First check the option sticker inside the glove box if it is still there. Second post the VIN number here from the tag inside the driver’s door, and someone will decode it for you. Probably had a 350 in it originally. You can also get the numbers off of the block and heads to decode. The numbers are located on the front passenger side on a pad that sticks out to the front of the valve cover. On the back on the block above where the trans bolts on the driver’s side. Here is a link that will help: http://www.mortec.com You can also find some code info here: http://www.nastyz28.com Have fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
newly minted old timer
one more place if you are lucky. they usualy tucked the actual build sheet in the springs of the seat. usualy behind the seat. work a look. you may get lucky
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
THE MODEL#CE15934 VIN#CE134SZ72251
4M49KKTURBO HYDRAMATIC 4C60EC A/C 4H05AR REAR AXLE 373 RATIO THANKS JBARTGMC |
![]() ![]() Join Date: Jul 2002
Welcome to the board from South Mississippi. I can't help you on the numbers. I only have stuff for GMCs up to 69. It probably is a 350 if it's original though. Like Hutch said, they surest way would be the block and head IDs..
its all about the +6 inches
Wasn't the base engine in a CE truck the 307?
That's what I'm thinking. I'll bet it's 307, unless GMC is different than Chevy on the base engine.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
