Old 08-24-2010, 01:47 PM   #1
REDNOSE65
REDNOSE65's Avatar
Impala steering wheel...
I went to install my 1965 Impala steering wheel on my rig yesterday. Didn't happen. The steering collum is off a 68 Chevy Pick Up. Do I need some sort of adaptor??? Or what do I need to install it? Any advice would be greatly appreciated. I don't have pics of the Impala steering wheel, but here's the collum and the steering wheel on it now....
Thanks in advance guys!!!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 08-24-2010, 03:41 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Impala steering wheel...
Don't quote me but I thought somewhere around '66-'67 GM changed the splines on the shaft and used that well into the late '90's. Anything earlier had to use early wheels or for an aftermarket steering wheel, an adapter for the earlier years. I think the '65 Impala wheel would have worked with your stock column but not the '68. This is going by memory back years ago when I bought an adapter and had to make sure I got the right year range.
Not sure if that helps but I am guessing there is not a way to get the '65 wheel onto the '68 column. Again, don't quote me 100%.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-24-2010, 04:53 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
To the best of my knowledge the splines never changed from when they started using them (in the 30’s?) until at least 1984, but there are at least two differences between the 55-68 & 69-84 attachments. The outer diameter of the later column is larger than the early models. In order to make the early wheel look correct, there is an adapter kit that provides a ring to attach to the back of the wheel, which matches up the size of the wheel to the larger column.
http://www.classicchevy.com/chevy-st...1955-1968.html
The bigger problem is the depth of the turn signal mechanism and locking/hold down plate within the newer column (essentially how high up the shaft sticks out of the column. I bought the adapter kit for mine, and attempted to install one of the smaller retro 59 Impala wheels. My column is a 69-84 aftermarket model from Butch’s Rod Shop (long since out of business). Some of the 69-84 columns are like mine having the turn signal mechanism and upper locking plate set too deep in the housing, while others have the switch and plate assemblies mounted nearer the top of the steering shaft.
Even though the splines matched up, it was impossible to install the wheel since the plastic back of the wheel ran into the column housing before the hub could seat on the splines, and I could barely get the nut to engage the first threads on the shaft. With or without the adapter ring, the wheel hit the column and when I tried to tighten the steering shaft nut, the wheel was clamped to the housing and could not be turned. If this is the problem you’re facing, the only option I know of is to replace the column with a something different. My budget was stretched to the limit so I gave up and sold the wheel instead. Someone else may have a solution to this problem but I didn’t come up with one.
Old 08-24-2010, 06:11 PM   #4
chevy_mike
chevy_mike's Avatar
Hummm... makes me wonder if the different adapters I saw wasn't due to the depth difference you talk about and nothing to do with shaft size. Interesting info...
Old 08-24-2010, 09:06 PM   #5
DPowers
DPowers's Avatar
http://www.crowderscustomizing.com/
Try contacting these guys- I used a '64 Impala column and a Dino steering wheel. I looked everywhere and these guys were quite knowledgeable and were able to hook me up.
DPowers is offline   Reply With Quote
Old 08-26-2010, 01:35 AM   #6
chopper john
chopper john's Avatar
if you go back to stock column you can run it no problem
chopper john is offline   Reply With Quote
Old 08-26-2010, 01:37 AM   #7
chopper john
this is mine
Old 08-26-2010, 09:28 AM   #8
Rogue
Airport Bum
I have been looking for a '61 Impala wheel for mine, that looks just as good as I imagined.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 08-27-2010, 12:42 AM   #9
chopper john
thanks brother. i also have a clean 63 steeringweheel ive been thinkin about putting on
Old 08-27-2010, 10:20 AM   #10
REDNOSE65
REDNOSE65's Avatar
It's looking that way.
Thanks for your input on this.
Yes that's exactly the problem I'm having.
Thanks for your input.
Thanks man.
ima see what my options are, but I may have to do that Johnny.
Thanks bro!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 08-31-2010, 01:34 PM   #11
REDNOSE65
REDNOSE65's Avatar
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
