Old 08-24-2010, 02:31 PM   #1
Relish
Relish's Avatar
deluxe side marker trim?
I was wondering if it is possible to get the trim only for the side marker lights?
Relish is offline   Reply With Quote
Old 08-24-2010, 05:56 PM   #2
AirSpeed
AirSpeed's Avatar
Re: deluxe side marker trim?
I've never seen anyone sell just the trim, I guess you could pry some off of some old ones but why would you want just the trim? You can buy new marker lights pretty cheap.
AirSpeed is offline   Reply With Quote
Old 08-24-2010, 07:48 PM   #3
Sammy
And after using a car wash or pressure wand about 4 times plan on using some trim adhesive or weather stripping adhesive as you will loose the trim. Which is probably what happened in his case. Thanks to Congress we no longer produce our own stuff and keep the rest of the 3rd world country's from starving.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-24-2010, 09:45 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Thumbs up Re: deluxe side marker trim?
Yep, just buy a set of repop deluxe sidemarker lights, wait about a week, and the trim falls off magically
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-25-2010, 12:11 AM   #5
70cst
70cst's Avatar
You can still buy NOS deluxe trim from GM. And yes...the repop trim does have a tendency to fall off.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-25-2010, 04:49 AM   #6
JRBECK64
NO Dont say they will fall off because I just put a brand new set on my Sons 69.LOL They sure do look good though. Are you talking about the Aluminum Rings that go around the outside of the marker lights?
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 08-25-2010, 05:04 AM   #7
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
JRBECK64
yep they will come off...need some real good adhesive...any suggestions out there?
-Ron-
OldSkool71 is offline   Reply With Quote
Old 08-25-2010, 10:02 AM   #8
1-PU70
1-PU70's Avatar
How many do you need? I just found some in the garage the other day. Hope I didn't Get rid of them.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 08-25-2010, 01:11 PM   #9
Sammy
Black 3M Weather Stripping Adhesive the excess color blends in to the black background. And you will pull the trim into removing the trim afterwards.
Old 08-25-2010, 05:42 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Contact cement works great
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-25-2010, 07:15 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I use the red model glue and they seem to be holdin..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
