Old 08-24-2010, 04:38 PM   #1
The Big Green
Need 22/24 tires help
I have a bodied 95 Chevy and I had two 22's and did a 6 lug swap so wheels are on the front. They are 22x9.5 with a 255/30/22 and I made the mistake and got a wrong width tire for it. The rim lip hangs out so far I can't tell there's a tire from the right angle and when I lay the camber this thing has the lip about touches the pavement, may even touch lol. I think it'll break the bead at any moment. I can't get two more 22's because they stopped making them so I'm going to the 24 and doing 22/24 combo. Here's the part I can't decide. If I do say a 275/30/24 then I can't really do a 285/30/22 like some guy told me because the tire heights will leave me taller up front in tires sidewall height. Basically I have 22x9.5, and I'll have 24x10 on back. I touch firewall hard on the 255/30/22 but if I relocate the wires on the firewall I'll be ok. I have 28in dia worth of room in the front and the rear I have no clue but I need my tires to match and not have the front wider and taller and keep the staggered look. The rear I have a stepside so with the rallies and 235/60/15 I'm already eating my fenders but I'm bodying a fleetside bed so I have no idea how tall I can go there. I have a 10in wheel with +40 or 7.1in bs.
The Big Green is offline   Reply With Quote
Old 08-24-2010, 06:44 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Need 22/24 tires help
What about putting your 22's on the rear and running a 20 up front?
Does the front 22" wheel offset work on the rear of the truck?
Keith
Convert to disc brakes.
Old 08-24-2010, 06:58 PM   #3
The Big Green
Yea I'm pretty sure it would fit on back. If I had anymore bs it go on import or something lol. The 22x9.5 has a 6.78bs and after seeing it on there a 20 would look tiny. I did think about a 20/22 but would rather do 22/24 if I can make it work, if not it's not worth it. I won't take a bodied truck and keep it from laying because the wheels and tires are too big. I have a pic of the wheel on it and I really like the 22 a lot on the front.
As for the rear I was gonna have the wheels on their way while I'm swapping the back to 6lug. I'll probably pull axles and redrill and I haven't had time.
Old 08-25-2010, 05:53 PM   #4
The Big Green
My 24's will be here Friday or Monday. I'm about set on the 275/30/24 for my rear 24x10's unless it'll be the same as my 22's and the tire not be wide enough. Would a 22x9.5 with 265/30/22, and the 24x10 with 275/30/24 be a good matching set and not look dumb?
