Lower A Arm Bushing Problems
So I ordered a set of lower control arm bushings for my 1/2 ton c10 last week from LMC.....When I went to put them in I noticed they had "threads", but not like the originals.....they were barely there and I could not get them to thread in!!!! So then i looked at the boxes the came in.... They were made by Three 5 auto.....then on the plastic they said Huong Sho motor co...... I was like great I got some Chinese knock offs. So I went to Napa and ordered a set from Master Ride..... almost the same thing except these look like they have relief cuts or something!!!! My question is.... are they all like this??? And if they are how did you guys get yours in???
Huong Sho is the first pic Master Ride is the second |
Re: Lower A Arm Bushing Problems
Mine looked like your second pic and they screwed in ok. I couldn't turn them by hand, but they weren't difficult with a socket wrench.
Try them on the shafts first. They have to turn easily there. Ray |
They turn fine on the shaft cause the shafts are brand new too.... I'll try the napa ones the give an update....just wanted to see if anyone else's looked like that before i take the front end apart again.......its my daily driver
Truck and auto performance nut
I got mine from CPP...and after seeing that I'm glad I did!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Firefighter
If you get the Napa NCP line they are made by DANA, cost more but a lot better product!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
i had the same problem, to fix the problem, buy moog. expensive, yes. go together like cake baby. no binding, no cross thread, easy fix. i did what you did and returned it all and bought moog.
