71 C-10 Drag/Center Link
The drag/center link is worn on my 71 C-10 so I thought that was easy enough. I went to several local parts stores and no one had one and they also could not order it. So I came home and got on the internet and no one carries the drag link. What I thought would be easy has turned out not so easy. Any suggestions?
Between Trucks...
Re: 71 C-10 Drag/Center Link
The drag link isn't repopped, a used one is the only option. Search Craig's List and the Parts Board here, as well as local junkyards. If you were a Site Supporter you could post a WTB.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 08-24-2010 at 06:11 PM. |
I didn't know that, rough deal. Suppose when mine quites it's porterbuilt dropmember & rack & pinion time.
"THE GREEN GOBLIN"
Forgive me for asking but what is The drag/center link,any pictures? It doesn't hurt to learn something new...
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Don't have a pic in my photobucket library but the drag/center link is the bar that extends from side to side connecting the steering linkage. Look under your truck (below your radiator) you'll see the bar
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
The center drag link is a non wearing part. The idler arm or pitman arm is a wearing part so what is worn on yours?
Fuzzy |
It appears the bolt on the driver's side was not tight and it wollered out the hole.
![]() Join Date: Jul 2010
Try a place called "RARE PARTS", in northen Ca. I think they have them.
There's a lot of trucks being parted out in the parts section of this forum. I'd be looking there.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Id pay the 20 bones and post a wtb ad..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 08-25-2010 at 07:03 PM. |
I actually tired "RARE PARTS" and they do not have it. I went the Charlotte Auto fair today, $35 for a used one.
"THE GREEN GOBLIN"
Thanks for the info?
