08-24-2010, 08:34 PM | #1 |
Hell yeah!!!
Show us your notches
I'm sure there's other threads on this but how bout some pics of your c notches.
Stock is good but custom is the sh*t! |
08-24-2010, 09:28 PM | #2 |
Jesse
Re: Show us your notches
08-24-2010, 11:20 PM | #3 |
Zombie Killer
Dude, that's nice! Bolt on and all, is that from PorterBuilt? What's something like that going for?
1964 C10 Long Step |
08-25-2010, 12:46 AM | #4 |
Hell yeah!!!
that set up looks pretty beefy. how long did it take to install?
08-25-2010, 01:48 AM | #5 |
DiablosWeldingFabrication
gor·geous
08-25-2010, 04:13 PM | #6 |
Jesse
Yes its Porterbuilts Trailing arm rear kit. It installed quick (check my build thread for dates) and check with Nate about price. Thanks
08-25-2010, 05:57 PM | #7 |
Hey nach! here's a kp notch with a watts link... cool huh this is the one i told you about before.
'66 c10ish straight 292 power! |
08-25-2010, 10:26 PM | #8 |
Hell yeah!!!
You know that frame will be able to take some abuse.
08-26-2010, 01:41 AM | #9 |
was up nacho. here is mine
08-29-2010, 11:10 PM | #10 |
Hell yeah!!!
still not done
08-29-2010, 11:23 PM | #11 |
Porterbuilt weld in notch:
08-30-2010, 03:21 PM | #12 |
these pics makin me wanna chop into the frame! but I wanna be able to use the bed - motorcycle hauler... If I did something like this on a C20 any idea how much to raise the bed floor? Thanks!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
08-30-2010, 09:31 PM | #13 |
Hell yeah!!!
it all depends on how tall your notch is gonna be. could be a few inches could be a foot. my days of hauling stuff around are over. not a bad thing when your friends only call you when they need help moving something.
09-01-2010, 12:08 AM | #14 |
looks good nacho
09-01-2010, 11:18 AM | #15 |
Registered Loser
Here's the ***************** 63-72 Chevy Superlift wishbone kit on my 63 GMC...
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
09-01-2010, 05:39 PM | #16 |
Hell yeah!!!
thanx johnny, I had to redo my exhaust. it was hangin a bit below the frame and when it was being backed out of the shop it got hung up and busted my ram horn exhaust manifold.
09-01-2010, 06:45 PM | #17 |
Chevy Only Tx
Chevy Only Tx......... |
09-01-2010, 06:47 PM | #18 |
Chevy Only Tx
09-01-2010, 06:52 PM | #19 |
Chevy Only Tx
Should have my porterbuilt panhard bar in this week and installed by the weekend, still need to fab shock mounts and throw on some gloss black and clear coat...
09-01-2010, 11:01 PM | #20 |
Not as extreme as others above, but here's my c-notches.. They are the $99 set from CPP, bolt in but I also welded them in..
My build thread: '66 Chevy |
09-01-2010, 11:06 PM | #21 |
Hell yeah!!!
That's quite a variety, let's get some more to put ideas out there and hopefully the streets will be full of lowered 60-66 trucks!
09-01-2010, 11:39 PM | #22 |
Used an old oxy tank for mine
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
09-02-2010, 02:15 AM | #23 |
Here's mine....
