What order to put a door together?
Which order do these items go together:
Vent Window Window felts/rubber strip Door lock Door lock button bar Interior door handle mechanism Door handle remote control bar Window regulator Window glass Window rear run channel Channel rubber strip
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
Re: What order to put a door together?
Vent window first & rebuilt with new rubber before put in door.
Window Glass Window regulator Window rubber strip with window still down Window rear channel Interior door handle mechanism The rest can be place in any order, worked for me two weeks ago.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 08-24-2010 at 09:04 PM. |
Thanks,
Sounds good except for one item. I just found out (another oops) after I got one vent window in, the regulator needs to go in before the vent window. The lower part of vent channel blocks the window crank shaft from fitting in the hole.
It may not help you what so ever. But with the door installed, installing the window becomes so difficult for me. I have found that gravity, limited visual inside the door and lack of patience makes this a time consuming process. But if I remove the door lay it flat I can do the job in very short order.15 min versus two hours.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
I just found a GREAT photo how to assemble a complete door!
http://www.sporttruck.com/techarticl...oor_parts.html To the " Move a Message" administrator: this could be moved to the body secvtion.
