6>8 Plugless........
![]() Join Date: Sep 2007
1969 K10 4 speed 300hp 350 $1250
I have decided to list this truck for sale because I just don't have the time to get to it like I thought I would have. It is rough, but I have started acquiring parts for it. The rockwell tcase is shot, but I have another 4 speed and a NP205 that goes with it. I also have a matching pair of axles from a 72 K5 that go with it. Front is a D44 disc brake front. I have some power brake brackets and the booster and MC, as well as the proportioning valve. It has a 4" lift and worn and weathered 35" BFG's on it. I also have a very nice 1972 grill shell inner and outer for it, a set of decent doors to replace the ones on the truck, and a pair of rust free fenders that have a couple of small dings in them. I have an extra front drive shaft, a seat core, the heater box and misc parts, an extra gauge cluster, that I will let go of with it. $1250 OBO.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 08-25-2010 at 12:33 AM. |
Re: 1969 K10 4 speed 300hp 350 $1250
is this what you were lookin for a cab for? sorry never got pics back to you on my 70 in primer. got some pics, just not loaded and sent. are the other axles 6 lug? what is rear? how is bed? thanx rich
Rich, yes was the truck I was looking for a cab for. The other axles are 6 lug, this bed is rust free, just rough. The RH front bed side is the worst part of the bed. I have another bed that is nicer I'd sell for $200. The rear I think is a 12 bolt but I'll check for sure.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Amazed Member
![]() Join Date: May 2010
I sure wish I were closer. I'd be bringing that to the house!
![]() 1950 3100 Original Project! |
Amazed Member
Original 6 Cyl Truck?
Grandpa in the rustmobile...
lol im glad your far away, could be a very sweet truck, would lvoe to have a 4x4...where you at in IA (what part, I have family up there)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Near Des Moines.
Title says V8, I'm pretty sure it has always had a V8 too by how it all looks.
I'm also including a van tilt which I have already started converting to a floor shift column.
id like to see some pictures of the other side, and the interior. also how much to meet me in davenport Ia?
Friends don't let friends drive fords. |
Deek, I'll dig up some other pictures for you. For the $1250, I'd meet you in Davenport at no charge and help you load it on your trailer.
Here are pics of the box that go with it if the truck sells within the next 2 weeks,.
#13 |
Here is a pic of the extra rear axle.
![]() And the extra front axle. ![]() I also have 2 Cheyenne10 emblems that I will let go with the truck if it is sold within the next 2 weeks. ![]() Here is a pic of the interior. ![]() And some pics of the LH side. ![]()
#14 |
So for $1250 as long as it sells before 9-28-10 you will get the following:
1-1969 K10 with a clean title, a good running 350 with an aluminum intake and an edelbrock carb, a 4 speed with a broken Rockwell 221 and a front and rear driveshaft, a 4 speed with a NP205, a Dana 44 disc brake front, a 12 bolt rear, a very nice 4x4 fan shroud for a sbc, a decent 8' box with minimal rust, 2 front fenders with minor dings and minor rust, an extra grill shell, an extra multi-gauge cluster, a van tilt column with no steering wheel, 2 doors one of which I will post in a pic in a few minutes, and 2 cheyenne10 emblems. Another thing I know it needs is front spring bushings because the front lh spring needs a rear bushing and the shackle bars need replaced. I have a stock set of shackle bars but haven't purchased the bushings yet. This is a project and the truck will need restored or it could be a fixer upper daily driver for a winter 4x4. If it doesn't sell by 9-28-10, I will part it out. It just needs to go before the white stuff flies. I will deliver up to 200 miles away for free.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 09-14-2010 at 06:30 PM. |
#15 |
Here is a pic of the LH side with the other LH door installed. This door needs repaired where the upper hinge mounts due to someone torching it off the donor truck. I did not catch that until I went to install it.
#16 |
![]() Join Date: Apr 2010
What gears do the replacement front and rear diff have? Is the title clear and matches the cab tag? I only ask because I have looked at 2 this summer that didn't match the title and 1 of them had no VIN tag at all. I am considering this for my winter project. I've already got a 69 K10 short, I'm trying to decide if I need another. I was looking for a 2wheel drive.
ROD ![]() 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
#17 |
I will have to check the gear ratios, because I do not know right now. Yes it has a clear Iowa title, yes the VIN on the cab and the VIN on the title are the same. Both the tags are still on the cab with the OE rosette rivets still in place. I also have the shifter for the NP205 I just remembered and it goes with it too.
#18 |
Sorry dieselwrencher Im gonna have to pass. I ended up buying something a few days after I left you the message.
#19 |
That's OK Deek.
#20 |
Sale Pending.
#21 |
Truck is sold. Thanks.
