350 exhuast manifolds
I'm looking to order a dual exhaust kit from lmc or something similar. I've got a '68 lwb with a '75 350 with stock manifolds. So my question is, could I order a kit for a '68 327? Did they use the same manifolds? And I'm pretty sure they share the same block right? also it 2wd.
'68 C10 LWB 6.2NA/NP833 3.73's |
Re: 350 exhuast manifolds
If they used the original manifolds when they changed engines the 327 pipes will fit. Sometimes it better to take it to a muffler shop & have them build a system. It should have ram horn manifolds that angle back about 45 degrees.
