08-25-2010, 02:21 PM | #1 |
what sway bar should i use for front
I'm going to install a front swaybar wanted get some info on which one to buy. What is the best one for the best price. And is their anything I could get one off of from a newer truck and install with minimal fab time. Tell me about the ride difference or any other thing that mite help me
08-25-2010, 05:39 PM | #2 | |
Re: what sway bar should i use for front
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-25-2010, 06:51 PM | #3 |
Grandpa in the rustmobile...
Depending on whatcha wanna spend...
Easiest but $ would be ECE, Around $150 everything you need Or you can do what me and many others have done, go to junkyard Get bar from 1/2 ton or 3/4 (prerbly 3/4 because it will generallly be bigger dia.) Get everything frmo the truck (you will have to grind rivits if you want the stock hangers) then go to orielly (they carry mogg) And get the correct bushings, paint the stuff and grind 2 rivits off your truck and intall bar very easy and cheap Bar-$30 from junkyard (i got mine from friend for 15$) Bushings-$25 give or take Brackets-free if you get them off the truck otherwise im not sure heres a link http://67-72chevytrucks.com/vboard/s...ad.php?t=72338 this is a HUGE upgrade for these trucks..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-25-2010, 06:53 PM | #4 |
PROJECT 7DEUCE
I agree with the junkyard idea thats where I got mine from....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-25-2010, 08:45 PM | #5 |
[QUOTE=Blackjeep99;4156872]I'm going to install a front swaybar wanted get some info on which one to buy. What is the best one for the best price. And is their anything I could get one off of from a newer truck and install with minimal fab time. Tell me about the ride difference or any other thing that mite help me[/QUOTE
I went junkyard on my Suburban, 1 1/4" with poly bushings . Do you have a 2WD ? didn't see in you're post.
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
08-25-2010, 11:05 PM | #6 |
Cruzin
i got mine from a junk yard off a 80's model 3/4 ton for $25, and bought ECE lowered truck brackets for $19+shipping, and new moog bushings from advance auto parts for about $25 or so
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-26-2010, 02:27 AM | #7 |
Laid Lo
Hubscrub got it right, plus the CPP one is heavier than the stock 1/2 ton one.
One of the biggest bang for the buck improvements you can make. Wish I had done it years ago! Out the door I was at about $125 for mine and it comes with everything, brackets, bushings, hardware etc. By the time you track down all the JY stuff and new hardware you'll be close to a better engineered one anyway. Both Danny and Jeff from CPP are members here. I'd shoot them a PM and see what they can do for you.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler Last edited by blime81; 08-26-2010 at 02:29 AM. |
08-26-2010, 02:32 AM | #8 |
My vote is junk yard 1-1/4" bar from a 73-87. Get the mounts with it. ~$50
Energy Suspension poly bushings -2 sets ~50 The Energy parts come with new straps and are greaseable. Grade 8 bolts/nuts/washers ~ $10 to $15 You can see mine peeking out here. Paint is hammered silver.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-26-2010, 10:47 AM | #9 |
used one from a chevy van g20 had to drill two holes in the frame |
