Old 08-25-2010, 02:33 PM   #1
bluec10
bluec10's Avatar
Truck Stalls When I Step on the Gas
Arrgh.
I've got a '69 GMC with an 250/3 speed manual. It starts well and idles well. BUT, when I step on the gas to let out the clutch, it stalls. I have to nurse the accelerator to higher RPMS by slowly applying pressure to the pedal. After its rolling it runs pretty well and runs reasonably well on the highway.
What am I missing?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 08-25-2010, 03:03 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Truck Stalls When I Step on the Gas
Things to check:
First remove the breather and check to see if the accelerator pump/plunger squirts gas into the carb. If it does then check for vacuum leaks. Mine had a gasket leak on the bottom.
Take the cap off the dist. and disconnect the tube to the vacuum advance. Suck on the end of the hose to see if the vacuum advance moves freely.
Check your points if you have them for proper gap and the timing.
Also, you may want to get a kit for the carb. They're easy to take apart and give it a good cleaning. Readjust the idle air screw for maximum vacuum at idle.
68gmsee is offline   Reply With Quote
Old 08-25-2010, 06:52 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
My money is on the accelerator pump not working...
LockDoc
Leon
Old 08-25-2010, 07:13 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
x3 on the accel pump
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 08-25-2010, 08:57 PM   #5
cparman
sharp as a marble
Before you condemn the carb, make sure that you have checked to see that the point gap is correct?
cparman is offline   Reply With Quote
Old 08-26-2010, 10:07 PM   #6
kevmic28
kevmic28's Avatar
plug wires too. check em.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
