4 speed driveshaft question
Does anyone know if there is a difference between a 4 speed driveshaft for 1/2 ton vs. one from a 3/4 ton? Both trucks are 8 ft bed trucks. Both trucks are leaf spring trucks.
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! Last edited by gregg72340; 08-25-2010 at 07:18 PM. |
Junior Member
Re: 4 speed driveshaft question
I put a 3/4 ton driveshaft out of '67 into a 1/2 frame with the 1/2 rearend. I had to get what some calls a "jump" u-joint in to match the 3/4 ton driveshaft to the half ton rearend.
I like the 3/4 ton driveshaft better because it has a heavier carrier bearing.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#3 | |
Thanks Gregg
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
#4 | |
"Conversion" joints should be available at your local NAPA or if you live in a big enough city to have a driveline/clutch shop, they will have them too.
You might get them at a "chain store" if you already know the part number..... ![]()
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Junior Member
I got the one for my truck at a Fisher's Auto Parts, also some places called Federated.
