Old 02-23-2003, 04:30 PM   #1
Mountain Man
How to install new fender emblems
Dumb Question - I have some new front fender emblems that I might install. How do I get behind the front fender to install the clips? Is there an easy way, or some trick I need to know?
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 02-23-2003, 05:20 PM   #2
Mudder
Mudder's Avatar
You may be able to get to them by taking the inner fenders off. Never have tried it with the fenders on the truck.
Mudder is offline   Reply With Quote
Old 02-23-2003, 05:27 PM   #3
mikep
Used to have a truck
mikep's Avatar
I got some push in clips at the hardware store just like the ones the tailgate handle bezel is held on with. They work great . No way to use the original type unless you take the fender off.
No truck :-(
mikep is offline   Reply With Quote
Old 02-23-2003, 05:28 PM   #4
Mudder
Mudder's Avatar
I have heard of those push ins but have never seen them. I heard that they would work.
Old 02-23-2003, 05:43 PM   #5
70c10
67-72 Addict!
70c10's Avatar
The aftermarket ones have barrell nuts. The easiest way is to remove the wheel liners. When I replaced mine I was able to squeeze my forearm in there on the passenger side and get the nuts on. The drivers side is a pain. I was only able to get the front nut on. I never bothered putting the rear nut on and it's been tight!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-23-2003, 08:16 PM   #6
casey
casey's Avatar
If your a real contortionist you can get them on with out removing the inner fenders, I did
casey is offline   Reply With Quote
Old 02-23-2003, 08:44 PM   #7
rigo
Flake Daddy
rigo's Avatar
one thing that works well when you can't get to the back side of the fender is to put a dab of silicone on the studs of the emblem place the emblem in place and put a piece of masking tape over the emblem to hold it on the fender till the silicone cures... great way to keep the emblems on...and they won't rattle if your panels vibrate.
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 02-23-2003, 09:29 PM   #8
19mike69
funny to see this post today because i just put a drivers front fender on this afternoon and had hell getting all the bolts that go around the fenderwell back in...in fact i could only get about half of them.....afterwards i was thinking how much of a pain it was going to be to put all the emblems back on after painting it....never thought about silicone or getting some other type of clips
19mike69 is offline   Reply With Quote
