![]() Join Date: Feb 2003
relocate neutral safety switch
just received a column shift steering column with tilt. i believe that it is from a 72 cheyenne. i want to relocate the NSS up the steering column a couple of inches. i have looked at lots of threads but have not come across ...how to do this? can someone give me a quick tutorial or point me to a play by play thread... thanks
Re: relocate neutral safety switch
First of all disassemble the column to remove the tubular shifting shaft. Take plenty of pictures so you can put it back together the same way. Moving the hole is straightforward. There is a square bar welded to the shaft that activates the switch. You will have to weld a new one further up the shaft. Good luck.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
![]() Join Date: Jan 2007
Check the FAQ's it's in there. I moved mine up...no welding just grinding.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
The Older Generation
There are a couple of threads in the FAQ about it. Don't know if they will help you or not.
- I don't know if you are familiar with the FAQ Forum or not. Scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the little down arrow on the right side of the box and scroll down to "FAQ Truck Tech". On that page go down to "Thread / Thread Starter: FAQ Index Thread". When you get into that scroll down to the "Interior related FAQ's". I could have just posted a direct link but there is a lot of good info in the FAQ section and now the new people that read this thread will know how to get to it. Thanks to Krue for indexing the FAQ's LockDoc
